07 JK stall/ wont start
That's a tough situation because you really need to be able to pull the plugs and turn the engine over to expel as much water as possible, and you need to drain the oil asap. Was your air filter wet?
It's beginning to look like "hit a puddle, nothing big" is an understatement, and the engine hydro-locked. Not turning over with the plugs pulled may indicate a bent rod or two.
Puddle went 3" under the body and I went thru them easily it's not like I was in the puddle for very long, might have sucked water up the pipe haven't checked the air filter I will when I get home
