TeraFlex 2.5" Coil Lift Kits and Coils
#93
Joe- I just want to confirm that there was no need for adjustable track bars on that silver one, and the steering and ride are straight as an arrow with no flighty steering issues??
#94
#95
Sponsoring Manufacturer
Correct. You do not need a front adjustable trackbar with these kits. We've found that with loosening the control bolts when doing the install that helps with avoid the flighty steering.
#96
What can I do to fix my issues? Please help!
#97
I just installed this lift this weekend and did not loosen the control arm bolts during the install and now I am having some problems with flighty steering and even experienced some D wobble (don't want to even say that bad word) after going over a set of railroad tracks...
I was driving mine yesterday on the freeway with high crosswinds and I felt it more now than stock, but I believe that’s just from the higher center of gravity.
#98
#99
So far I’ve driven it up to 85 mph on the freeway and over railroad tracks (one set off a divided highway at 65 mph) and haven’t had any sign of the “DW”. From what I’ve read here, most of the time the problem is solved with the proper torquing of the trac bar bolts.
The FSM also has torque setting the sway bar links and shock absorbers. I don’t know if mis-torquing these bolts would case the “DW’ or flightyness.
