TeraFlex 2.5" BB Info Update!!
#92
I installed the BB last week and mounted the rear sway bar links on the inside due to still having stock wheels. However, I did need to drill a new mounting hole on the lower mount point for them to fit on the inside. Also, it looks like the top bolt will make contact with the brake lines under flex.
I'm getting new wheels this weekend with 4.25" of backspacing. This should allow me to move the swaybar links back to the outside.
#93
This made my decision easier...
Wow... this kind of willingness and community support just made my decision on which lift kit to purchase a LOT easier. Now I just need to decide between the Teraflex 2.5" BB or the 3" kit. I'm leaning towards the 3" kit right now...
Major Kudos to Teraflex and the other vendors on this forum!
#94
#95
Yeah...I've already bent them in a bit. That was the first thing I did when I installed the kit. I'd rather not bend them in any further, it might cause other problems. The more you bend them the further away from the frame the hard lines become making them more prone to be in the way of something else. You could then bend the hard lines, but where does it stop? Bend this, bend that. Might as well replace the flex lines with longer ones and remove the extension brackets at that point....
-Ben
-Ben
