Sneak preview of our own transmission cooler .
Old 08-01-2011, 04:00 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by thrshr01
That is a massive trans cooler. Have you guys tested the flow of the fluid and see if it has any effect on the pumps efficiency?
No we have not thats the next step and we will try to do a video of the test .
Old 08-01-2011, 04:09 PM
Brashanic's Avatar
Does it resolve the leaking factory hoses?
Either way I want one. Post or pm contact info I will purchase tomorrow.
Old 08-01-2011, 04:50 PM
EarlyJk's Avatar
Too big...Too much coin.... B&M is where its at.
Old 08-01-2011, 04:57 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Ok i just wanna mention this.
Again this cooler is not for everyone this is for the hardcore driver. We get our test JK thru Baja,washes,silt beds and more we made this cooler with parts that we know are racing quality and are not going to brake in the middle of nowhere , we test them on our vehicles and if they don't work we try not to sell them.
There was a question if we seen any difference in the temperature on the radiator and we did not notice any difference i also found this:
http://www.dana.com/wps/wcm/connect/...df?MOD=AJPERES
Will putting an oil cooler in front of the
radiator increase the engine operating
temperature? Not normally. Putting an auxiliary oil
cooler in the system decreases the temperature in the
radiator in-tank oil cooler and this in turn puts less load on
the radiator. From a total system standpoint, the engine
operating temperatures should vary little from where they
were before the oil cooler was installed.
Now we are going to have different size coolers depending on your needs. Wr are also going to have packages on just the brackets or mounts and we are having a b&m cooler to test fit that way if it works we can offer you a less expensive package.
Thanks
Gus V.
Old 08-01-2011, 04:58 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by muddenjeep
That price is really steep and that cooler maybe a little over kill.
We are going to have smaller sizes available.
Thanks .
Old 08-01-2011, 04:59 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by rmplstlskn
Love the mounts
Two hundred forty is a lot of dingdongs
We can also sell just the mounts or brackets with out the cooler.
Thanks
Gus V.
Old 08-01-2011, 05:02 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by kabookie10
Iran an engineer also and what I know is over designed is good but if it costs to much and puts thought of the market you wont sell very many. And while like the design I think your asking way to much. Good try though
Well we can run a cheaper but again this is why we have this as our heavy duty jk trans cooler.
Old 08-01-2011, 05:03 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Originally Posted by cfr
What hose fittings are you using? Do you have any before/after transmission temperature readings on a particularly abusive drive?
We are getting those we are going to work on a stock jk and one that has the cooler to compare the readings.
And then post pics and videos.
Also we are using treaded in fittings not the push on style.
Thanks
Gus V.
Old 08-01-2011, 05:04 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Are you talking about the rubber hoses ?
Old 08-01-2011, 05:10 PM
Sponsoring Vendor
ORW Representative
ORWJK's Avatar
Again we go with quility products and im not saying that B&M is not quality but we go by what we use in the desert we know it works and again thats why we are going to have different options and prices to work with everyone.
Thanks for eveyones input this what we need and please keep them coming.
Thanks
Gus V.
Quick Reply: Sneak preview of our own transmission cooler .
