OME JK Long travel Suspension Lift!! Details Inside
#51
With an '08 Rubicon Unlimited, will a new drive shaft be required? What about the Currie sway bar links since I have the electronic sway bar disconnect? Lastly, not to restart the whole upper vs. lower arm thing, what about rear arms? Doesn't the rear pinon angle need to be adjusted or does it just work out ok?
#52
Sponsoring Vendor
David
#59
Thanks for all the help today Dave! Looking forward to getting the kit next week. Is there an online installation sheet for the kit so I can start getting my new garage up to speed. Think I will have to get it done by someone other than Matt as he won't warranty the work with the mix of components.
The OME JK Long travel kit is finally in stock and ready to ship!
Here is what it consist of
OME HD front and rear coils
OME Long travel Shocks
Teraflex Front and Rear Bumpstops
Currie Rock Jock Sway bar Links Front and Rear
JKS Front and Rear Trackbars
Crown Stainless steel Brake lines
Currie Front Upper control arms
Currie Rear Coil Spring retainers
All this shipped to your door for 1499.95
This lift will work on 2 door and 4 door Rubicon and non Rubicon models. The lift will net approx 3" of lift and have A whole bunch of travel!
If you already have a OME kit and need the bumpstops we have them in stock and ready to ship also .
Thanks
David
Thanks
David
#60
Sponsoring Vendor
No sorry no online instructions and If matt wants to be like that take it somewhere else.
If anybody has any problems with this kit (Which you wont) we will take care of you!
David
David
