OME JK Long travel Suspension Lift!! Details Inside
Old 02-16-2009, 01:03 PM
  #31
Sponsoring Vendor
Northridge4x4's Avatar
Already replied to your other post.
David
Old 02-16-2009, 08:11 PM
  #32
FireRescue707's Avatar
David, I have 4" ProComp springs on my jeep already. Will this set up still work with my springs? I like the ride height on my jeep as it sits now.
Old 02-17-2009, 07:50 AM
  #33
Sponsoring Vendor
Yes the kit will still work and you can keep your springs.
David
Old 02-17-2009, 05:29 PM
  #34
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
Why do you need bump stop extensions?
Old 02-18-2009, 08:31 AM
  #35
Sponsoring Vendor
With the long travel kit the shocks are longer than the standard shocks so bumpstops are needed so you dont over compress the Shocks.
Also if somebody is buying the long travel kit I tend to think they are going to wheel it harder than a guy with the standard kit so bumpstops are nice to have under extreme flexing situations.
David
Old 02-18-2009, 10:08 AM
  #36
seal20's Avatar
David
What happens if you over compress a shock? I've heard of this, but never actually seen it. I am concerned about my rears now that I did the EVO Rockstars...
Old 02-18-2009, 10:22 AM
  #37
Sponsoring Vendor
If you use your shock as a bumpstop it can do a number of things
- Blow the seal
- Break the shaft
- Ect
Not good.
Old 02-18-2009, 12:37 PM
  #38
New-B's Avatar
David, do we need new bumpstops if we have bumpstops from a BB already installed?
Old 02-18-2009, 12:46 PM
  #39
Sponsoring Vendor
No you will be good to go
David
Old 02-19-2009, 07:44 AM
  #40
pkess3's Avatar
David,
I currently have 2" bumpstops on the rear axle for my current OME setup. Will I need taller one's for the long travel shocks or can I use the 2 inchers?
BTW, got the shocks yesterday as promised. Thanks! Just waiting for the control arms to arrive Friday.
Quick Reply: OME JK Long travel Suspension Lift!! Details Inside
