OME JK Long travel Suspension Lift!! Details Inside
Both Uppers and Lowers can fix the "flighty" steering and this is becuase they have the ability to adjust the castor angles.
The front uppers do this very well and are the most cost effective way to do this.
Now the Front lowers will also work very well and give you a stronger lower but they are more expensive than the front uppers.
David
David
Sponsoring Vendor
Upgrade kit for 599.95 shipped and it would include These items
Teraflex Front and Rear Bumpstops
Currie Rock Jock Sway bar Links Front and Rear
Crown Stainless steel Brake lines
Currie Front Upper control arms
Currie Rear Coil Spring retainers
David
David
Man this is almost the complete hybird kit I just put together. Only real difference is I bought the complete arms (all 8). I will say the ride is very nice and much improved from when I had stock and also from the BB. The long travel shocks in combination with a nice set of springs = NICE RIIIIIIDE.
Dave one question. Why do you recommend the rear spring retainer and not also the one for the front? I beleive the ESP cable will rip out prior to the spring popping out.
Sponsoring Vendor
The rear coil has a tendancy to slide out of the pocket when you flex it alot so the rear coil retainer is nice to have not needed though.
The front will not have this problem and the ESP cable has never been a issue that I have seen.
David
David
is this a limited time offer kind of thing, or will this be a permanent kit on your site? It sounds like exactly what I'd like to do to my jk at some point, but unfortunately the funds wont be there to do it for quite sometime.
Sponsoring Vendor
This will be something we will get on the site or will always have, The only thing is some of the components may change brands if some MFG's have price increases , new better products come out, or If we cant get the part listed.
David
If not how much to include the shocks with the upgrade kit?
