NEW!! TeraFlex JK Leveling Kit!! $129.99
#157
I run a very similar setup. I had to get a few other parts to make it drive great again. Mostly front lower control arms. But they may not be needed for you. I ended up with about 2.75" of lift or so total (measuring from axle to frame).
#158
#159
Originally Posted by Rhino64
I run this with 19/59 all that was required was to re-center my steering wheel,drives fine.
#160
I was thinking of getting this kit as well. I have one question that no one seems to of thought of. My 2011 does not have the e-disco and was wondering if anyone has also run the "Teraflex JK Wrangler 0 - 3" lift front swaybar disconnects (7153010)" with this setup?
Just thought of something else. If you have to adjust the headlights do you also need to adjust the fogs as well? I use my fogs on a daily basis in the winter months up around Grande Prairie Alberta. It can get pretty fogged in there. (I've seen the write up on adjusting the heads)
Cheers
Cheers
