NEW!! TeraFlex JK Leveling Kit!! $129.99
Old 07-31-2011, 10:08 PM
  #151
FrankCastle01's Avatar
can I add this to an existing 2.5 TF BB?
Old 07-31-2011, 10:12 PM
  #152
JKDrummer's Avatar
Originally Posted by DiabloM3
Can you run 35's with flat fenders and aftermarket bumpers?
yes sir!.......
Old 08-02-2011, 09:55 AM
  #153
bump..........................
Old 10-21-2011, 03:20 PM
  #154
njdan's Avatar
If i order this kit to go with my 285/70/17 on stock rims will I need anything else? I have already ordered 1.5 spidertrax spacers.
Old 10-21-2011, 03:49 PM
  #155
Sponsoring Manufacturer
TeraFlex's Avatar
I would not suggest that.
Old 11-18-2011, 07:46 AM
  #156
farm7's Avatar
I just got the leveling kit in today I also got a set jku springs 18/57 from a friend will that setup be a problem together on my 2 door
Old 11-18-2011, 07:58 AM
  #157
Stuka's Avatar
I run a very similar setup. I had to get a few other parts to make it drive great again. Mostly front lower control arms. But they may not be needed for you. I ended up with about 2.75" of lift or so total (measuring from axle to frame).
Old 11-18-2011, 08:08 AM
  #158
Rhino64's Avatar
I run this with 19/59 all that was required was to re-center my steering wheel,drives fine.
Old 11-18-2011, 08:35 AM
  #159
farm7's Avatar
Thanks how did you re-center the steering wheel
Old 11-18-2011, 09:46 AM
  #160
Kaisoboy's Avatar
I was thinking of getting this kit as well. I have one question that no one seems to of thought of. My 2011 does not have the e-disco and was wondering if anyone has also run the "Teraflex JK Wrangler 0 - 3" lift front swaybar disconnects (7153010)" with this setup?
Just thought of something else. If you have to adjust the headlights do you also need to adjust the fogs as well? I use my fogs on a daily basis in the winter months up around Grande Prairie Alberta. It can get pretty fogged in there. (I've seen the write up on adjusting the heads)
Cheers
Quick Reply: NEW!! TeraFlex JK Leveling Kit!! $129.99
