NEW! Quadratec Q10000C Comp Winch with Synthetic Line!
Old 01-07-2014 | 09:51 AM
quadratec's Avatar
Sponsoring Vendor
Cool NEW! Quadratec Q10000C Comp Winch with Synthetic Line!
Purpose built for serious off roaders, our Comp winch combines the muscle you need with all of the features you want. The smaller drum better utilizes the “power zone” which is the first two layers of line on the drum. Higher layers rob your winch of power so there’s no need spool rope out to get to it. Our compact winch is about half the weight of comparably rated winches with 100’ of steel cable.
Engineered for Jeep Wrangler, our competition style winch features a fast line speed of 8.6 feet per minute; a 10,000 lb. pull capacity and weighs only 55 pound! Lessening vehicle weight frees up horsepower and increase fuel mileage!
Comes complete with 50’ of Dyneema® synthetic winch line; an ultra-high molecular weight polyethylene fiber that’s soft and flexible yet stronger and more durable than steel cables. Each winch line includes a 6’ ballistic nylon chafe sleeve to protect your winch line from abrasions. Synthetic winch lines are a real game changer in off road recovery. In fact, when properly cared for, Dyneema® winch lines can outlast steel cables. Weight for weight, Dyneema® is 15 times stronger than steel and its light weight significantly improves the ease of handling. It even floats which is an obvious benefit when winching in water conditions. Dyneema® will not rust, kink and loose strength like steel cables can. Handling steel cables can sometimes result in wire splinters but synthetic winch lines are much safer and easier to use. In the unlikely event of a synthetic winch line breaking there is virtually no recoil. The ease of handling, increased safety and improved longevity of Dyneema® are why so many off road enthusiasts are making the switch. Each winch line is 3/8” diameter and rated for 18,000 lbs.
Other features include a billet aluminum hawse fairlead, deluxe winch hook and Winch Operator’s Guide with helpful information on winching and the care and use of synthetic line.
Available in satin black and signal red finishes.
Click on either of the photos above or here for more information:
Quadratec Exclusive 92122 2050 - Quadratec Q10000C Compact Winch with Synthetic Line - Quadratec
If you PM me with your order I can provide free shipping with removal of the $19.99 shipping surcharge for winches!
-Rick
