Level 8 Motorsports - Tracker
Old 03-16-2012, 06:42 AM
  #41
4fit?'s Avatar
Originally Posted by Foxc
Anyone with 15" trackers yet??? Pics please...
Check out my thread from a month or so ago. I ended up going w different direction cause I feel the 15" Trackers just stick out too far with that 3.32" backspacing.
https://www.jk-forum.com/forums/show...pinions-needed!
Old 03-16-2012, 08:13 AM
  #42
Foxc's Avatar
thanks for the pics. I think it looks great. Thats the setup I'm looking at too: MTR/K 35's on 15". I am leaning towards a rock Krawler 2.5 max travel lift on a JKU. Do I need to worry about rubbing on the fender flares with 3.32 back space?? really like the look though!!
Old 03-16-2012, 09:25 AM
  #43
Sponsoring Vendor
Discount Tire's Avatar
The fender clearance won't be an issue.
The only issue you need to worry about is finding the tires! As of right now the 35x12.50-15 MTR w/Kevlar is on back order with NO ETA.
Old 03-16-2012, 09:27 AM
  #44
Sponsoring Vendor
Originally Posted by Runewolf1973
Very sharp
Old 03-18-2012, 09:37 AM
  #45
Runewolf1973's Avatar
Can you guys please post the correct wheel sizing (backspace/offset) available for this wheel? I ordered and received my 18x9 Trackers with 5" backspace and 0mm offset because I was told over the phone that they only actually come in that spec for the 18x9's. When I got my rims in, I measure them just to check. I think this is the right way to measure backspace, but not 100% sure though. It reads 5".....
Thanks!
Old 03-19-2012, 07:33 AM
  #46
Sponsoring Vendor
Thanks!
The 18x9 Level 8 Tracker in the JK 5-5 bolt pattern has 0 offset which equals 5 inches of backspace
You are measuring for backspace correctly in that photo.
Old 03-19-2012, 10:39 AM
  #47
Originally Posted by Discount Tire Direct
The 18x9 Level 8 Tracker in the JK 5-5 bolt pattern has a 0mm offset which equals 5 inches of backspace
Thanks!
Just in case anyone here is concerned with how the 5" backspacing will work, I snapped a few pics... I did not need spacers either, not even close.
Kinda hard to see, but there is lots of room at the rear links...
Here is the front at full lock. I had my GF holding the wheel as far as it would go. You can see where my previous tire/rim set-up rubbed the lower control arm. Doesn't do it anymore... My previous rims were actually 5.7" backspace and they only rubbed a little on full turn...
At full turn, not touching the control arm, not even close...
About 1.5" of tire sticking out of the fenders on both sides with the 5" backspace...
Very happy customer. I thought 5" backspace would be a tight fit, (everyone always seems recommends 4.5") but the 5" is perfect IMO.
Old 04-01-2012, 07:46 PM
  #48
road_king's Avatar
I'm ready to purchase the polished 17x8.5 -6 offset for my '08 Rubicon with 35" MTR/K's.
That should be a good fit - yes?
What is the availability? I'm leaving the area I'm in now - 92211 in a couple of weeks.
Thanks
Old 04-02-2012, 10:29 AM
  #49
Sponsoring Vendor
Thanks
We do not inventory the polished 17x8.5 ET -6 (4.5" BS) Tracker but we can order a set in for you. Lead time is typically 7 to 10 business days to your door.
Here's the link with more details.
http://www.discounttiredirect.com/di...ck&tmn=Tracker
This wheel will work great with 35" tall tires
Give us a call at 1.888.459.4080 and anyone of our sales agents would be happy to assist you with this purchase.
Old 04-02-2012, 01:00 PM
  #50
road_king's Avatar
Thanks, I just ordered.
Quick Reply: Level 8 Motorsports - Tracker
