Jeep JK Magnuson Supercharger - install and impressions
#41
#42
#43
I like it too, but when are we likely to see this on the market, and of course, when will there be one for the 2011 Jeeps. Superchips has been promising a tune for the '11s for over two years, and still nothing.
#44
#49
Tvs 1320
I'm extremely interested in this kit. It's either this or the Prodigy Turbo for me. More info would be awesome. I'm about 2 weeks from being able to pull the trigger. When is this kit available for delivery and what is the boost pressure with the pulley provided? Also, what do I do if I add the Ripp headers...could the canned tune that comes with the blower handle that or would I need to be custom tuned? Obviously custom wouldn't hurt.
I have a 2 door Sahara that has been patiently waiting for a power adder and this thing has shown its pretty face at the perfect time!
So everyone knows...this is the same blower that is fitted from the factory to the 2009-current Audi S4 and that 3.0 direct injected V6 is good for 333 HP....stock.
#50
Specs from Magnuson
They do list this on the website but you can use the drop down tools. It's under products on page 2 or 3.
Currently this is the only data listed.
Fitment
2007-2010 Jeep Wrangler 3.8L
Features
TVS1320 Hybrid-roots supercharger.
Installs in one day.
100% complete bolt-on system.
No hood modifications are required.
More power in a smaller package.
Internal Bypass Valve virtually eliminates parasitic loss (uses less than 1/3 of a horsepower at 60 mph).
Delivers a proven increase in real world "under the curve" power.
High thermal efficiency.
2.4 pressure ratio capability.
High helix four-lobe rotors with 160deg. of twist.
Improved air-handling characteristics.
Acoustically designed for noise and vibration reductions.
Utilizes all factory "push-lock" connectors
Included Components
6th Generation MP1320 TVS Supercharger with integral bypass valve.
High flow fuel injectors.
Liquid-to-Air Intercooler.
Diablo Sport Predator Handheld Programmer.
Large front-mounted heat exchanger.
All necessary fittings, lines, belts, and hardware required.
Warranty
Standard 3-year/36,000 mile Warranty on the supercharger hardware.
Standard 1-year Limited Warranty on electronics.
Maintenance
Only requires an oil change every 80,000-120,000 miles.
Emissions Status
CARB EO# Pending
Tools Required
Metric wrench set
1/4in. - 3/8in. and 1/2in. drive metric socket set (Standard and Deep)
3/8in.and 1/2in. drive foot-pound and inch-pound torque wrenches
Belt tensioner wrench
Phillips and flat-head screwdrivers
1/2in. breaker bar
Fuel line quick disconnect tool (included in kit)
Small or angled 3/8in. drill
Drain pan
Hose cutters
Hose clamp pliers
Safety glasses
Torque angle meter
Hammer
Compressed air
Blow gun air tool
Metric Allen socket set 3/8in. drive
Shop vacuum cleaner
Blue Loctite
Right Angle drill for pinning crank pulley (when required)
Helpful Tool: Air or electric impact wrench
Install Time
8-10 Hours
CARB Executive Order:
EO# Pending
Size and Weight
Number of Boxes: 2
Box 1 Size: 34"x20"x16"
Box 1 Weight: 85 lbs.
Box 2 Size: 27"x14"x18"
Box 2 Weight: 40 lbs.
Fitment
Features
Included Components
Warranty
Maintenance
Emissions Status
CARB EO# Pending
Tools Required
Metric wrench set
1/2in. breaker bar
Drain pan
Hose cutters
Hose clamp pliers
Safety glasses
Torque angle meter
Hammer
Compressed air
Blow gun air tool
Shop vacuum cleaner
Blue Loctite
Install Time
8-10 Hours
EO# Pending
Size and Weight
Number of Boxes: 2
