EVO MFG Tire Carrier in STOCK
Old 11-12-2012, 09:07 PM
  #71
BoogieMan's Avatar
Are there any upgraded latch pins from the ones sold with the carrier?
Old 11-13-2012, 05:55 AM
  #72
blockrockin's Avatar
i used these from harbor freight ..thats the only thing i didnt like about the carrier
Old 11-13-2012, 08:27 AM
  #73
Sponsoring Manufacturer
EVO MFG's Avatar
Originally Posted by fadeout
So while browsing SEMA photos I came across Mopars Apache project again and noticed something about the way they have the tire carrier setup. They have the bottom joints rolled out a lot and this causes the carrier to shift upward. My questions are simple, is there any benefit to running the carrier this way as compared to having the joints all the equal length? Does this cause any added stress on the brackets or carrier itself being shifted this way? I have it setup with all the joints equal length it sits flat so to speak with the Jeep, but I only have a 37 x 12.50 on it now and shifting it up looks like it would actually add some extra ground clearance and added departure angle, I don't think I would do it as much as they did but maybe a little more than it is now. Would this damage or not be advisable do to the way the carrier is actually designed? I asking because you guys made it and would know the limits and strains on the components better than myself.
how mine sits now
Mopar's setup courtesy WAYALIFE.com
its just how they wanted to adjusted. It will not hurt anything
Old 11-13-2012, 08:53 AM
  #74
fadeout's Avatar
Thanks!
Old 11-13-2012, 11:36 AM
  #75
BoogieMan's Avatar
Thanks for the info.
I saw two different latch pins, easy grip hitch pin and the 4" hitch pin. Which one did you use for your tire carrier?
Old 11-13-2012, 12:26 PM
  #76
BoogieMan's Avatar
I forgot to ask this.
What can I use to mount my license plate on the EVO tire carrier?
Old 11-13-2012, 03:19 PM
  #77
it comes with a built in mount for the plate.. you just need a light..
Old 11-14-2012, 07:40 AM
  #78
EVO MFG's Avatar
exactly, You just need to add a light.
Old 11-14-2012, 07:48 AM
  #79
Prime8's Avatar
Are lit license plates required for all states? Illinois?
Old 11-14-2012, 07:53 AM
  #80
Sponsoring Vendor
chris@offroadevolution's Avatar
Just call your local Police Department , ask to speak with a Traffic officer. I would assume its the law in every state. I know it 's a requirement in Ohio and California.
Quick Reply: EVO MFG Tire Carrier in STOCK
