15" Alloy Wheels VS. 15" Steel Wheels
#901
Sponsoring Vendor
do you have an estimate on when the general grabber at2 in 33/12.50/15 will come off back order?
if so how much for a set of 5 with the black mb72?
if it's going to be a while, then how much for those with falken rocky mountain ats
hoping to be ready to buy after taxes get done
Thanks
Thanks
The 33x12.50-15 Grabber A/T2 is slowly being released right now so we should be able to order a set in for you. Here's what you would be looking at:
15x8 MB72 - $99.00 each
33x12.50-15 AT2 - $171.00 each
Lug Kit - $45.00
TPMS Valves - $40.00 per wheel (if needed)
Non TPMS Valves - $3.00 per wheel
Mounting - FREE
Balance - FREE
Shipping - FREE
Discounts - $40.00 OFF 4 new MB72 alloy wheels
Discounts - $50.00 OFF JK member discount for purchasing 5 tires
Give us a call at 1.888.459.4080 and anyone of our sales agents would be happy to assist you with this purchase
#902
Hi discount tire direct, you seem like the go to guy here. I see people are running 15" and 16" wheels with / with out problems. Does this mean I can run a 16.5" tire, with no problems? The wheel and tire combo I want is, 38" x 11 x 16.5" Super swamper boggers , with aluminum wheels. A lot of people are going to 37"s but they are wide. This 38" bogger is only 11" wide. So i figure it should be a lot lighter than the 37" and I should have room to turn it. I also like the look of a tall, narrow tire. P.S. I have a 4" lift.
#903
Sponsoring Vendor
#906
If you can find a a 16.5" wheel in the correct offset and bolt pattern there is no reason as to why you couldn't run them. We currently do not offer any 16.5" wheels for the JK but if you find a model you are interested in that is let us know and we'll see if we can order them in for you.
#908
#909
Sponsoring Vendor
Cool thank you for the help. I'm just looking and planning for when my current set of tires wear down. I didn't think about the off set. If people are running 15" and 16". Maybe I'll look at them too. I am more concerned about getting a narrow 11" wide Tire, than the rim size (as long as they fit) or manufacturer. I will keep the off set in mined. Once I find what I'm looking for I will look you up, thanks.
#910
Just orders these in 16. They will fit
No problems right? Also I put in the comment section if I could get black lugs instead. Is that possible? Or is there a way to upgrade to locking lugs?
