15" Alloy Wheels VS. 15" Steel Wheels
#491
If anything a large tire with small rim is better for airing down than the same tire size with a big rim. You just have more rubber to work with until you get to the rim. I'm no expert, but I think it's fairly commonsense. 15" was the standard wheel forever and people put huge rubber on it. These huge rim sizes are a fairly new fad.
Ok, thanks!
#493
After severral checks, rechecks, and re-rechecks, I've finally got all the rubber contacting the road, and a great daily driver pressure, and super O/R pressure, for lazy days when I don't feel like airing down.
26psi Frt
25psi Rear
Give it a try some of you DT owners, tell me what you think.
#495
#496
Makes perfect sense to me, as I'm running my DuraTrac 33-12.50x15's lower than the original GY 17"(oem size). And I get quite good off road performance with my daily pressures, even off road, though it is still better aired down.
26psi Frt
25psi Rear
26psi Frt
25psi Rear
Sent from my DROID2 using Tapatalk
#497
I just ordered mine from local discount and they matched it. Man rubber went up. One wheels on backorder so
Have to wait a while for 5th
Reason for order
[/QUOTE]
Reason for order
[/QUOTE]
#498
anyone know what the actual height of this set up is 15x8 mb72's with 35x12.5x15 km2's. Picking jeep up in a little and need to use the programmer and don't have a measuring tape
#499
