15" Alloy Wheels VS. 15" Steel Wheels
Old 05-18-2011, 12:02 PM
  #491
DJSJK50's Avatar
Originally Posted by Mastiff
If anything a large tire with small rim is better for airing down than the same tire size with a big rim. You just have more rubber to work with until you get to the rim. I'm no expert, but I think it's fairly commonsense. 15" was the standard wheel forever and people put huge rubber on it. These huge rim sizes are a fairly new fad.
Ok, thanks!
Old 05-18-2011, 06:46 PM
  #492
bstpierre's Avatar
Isn't it true that a taller sidewall allows you to run at a higher pressure with the same effect as a shorter sidewall at a lower pressure?
Old 05-19-2011, 03:14 AM
  #493
kliff's Avatar
Makes perfect sense to me, as I'm running my DuraTrac 33-12.50x15's lower than the original GY 17"(oem size). And I get quite good off road performance with my daily pressures, even off road, though it is still better aired down.
After severral checks, rechecks, and re-rechecks, I've finally got all the rubber contacting the road, and a great daily driver pressure, and super O/R pressure, for lazy days when I don't feel like airing down.
26psi Frt
25psi Rear
Give it a try some of you DT owners, tell me what you think.
Old 05-19-2011, 03:19 AM
  #494
kliff's Avatar
Originally Posted by tpoag
Works better with the pictures!!
Looooookig Goooood man!
Old 05-19-2011, 06:36 PM
  #495
tpoag's Avatar
Thanks! I have been running 30 psi front and back and have noticed the outside edges of the tires don't seem to be making contact. I will try your pressures and see how they look.
Old 05-20-2011, 05:25 AM
  #496
Black 08 X's Avatar
26psi Frt
25psi Rear
You are running a 8in wide wheel correct? Unlimited? Sorry on my phone and can't see your sig.
Sent from my DROID2 using Tapatalk
Old 05-23-2011, 11:26 AM
  #497
Ruckus99ss's Avatar
I just ordered mine from local discount and they matched it. Man rubber went up. One wheels on backorder so
Have to wait a while for 5th
Reason for order
[/QUOTE]
Old 05-24-2011, 08:57 AM
  #498
Ruckus99ss's Avatar
anyone know what the actual height of this set up is 15x8 mb72's with 35x12.5x15 km2's. Picking jeep up in a little and need to use the programmer and don't have a measuring tape
Old 05-24-2011, 12:09 PM
  #499
Bosox5's Avatar
buy a measuring tape! you will need one in the future for sure, and they are cheap.
Old 05-24-2011, 03:04 PM
  #500
Cliff0128's Avatar
34.6 inches
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
