15" Alloy Wheels VS. 15" Steel Wheels
#471
Sponsoring Vendor
Digging the Matte Black MB 72's. I dont speak "back spacing" very well so i need some help. I have a 011 JKU Rubi, stock suspension. My current plan is to keep the stock 32's, and just upgrade the wheels, eventually, of course, going lift and 34-35's/10.50-12-50.
Basically i'm saying i wanna buy wheels i wont have to replace because of lift/bigger tires down the road.
Suggestions? Any current specials?
Thanka
Thanka
The 17x8.5 ET-6 (4.5" BS) will work on your JK but you'll want to get some wider tires as the 255/75-17 OEM size is a hair to narrow for an 8.5" wide wheel and will stretch.
The wheel dimensions are perfect though for tires up to 37"
#472
Thanks for the info!
Stretching sounds less than ideal
I was trying to avoid having to get both new tires and wheels at the same time but if i am reading your comments correctly, it looks like i wont be able to pull off my original plan. Is this correct?
thanks for your help
#473
Sponsoring Vendor
You could run another wheel model in size 17x8 with either a 0 offset or -6mm offset. The 8" wide wheel will work with your factory tires.
Here are a couple options.
http://www.discounttiredirect.com/di...r=3&wd=17&rw=8
http://www.discounttiredirect.com/di...r=4&wd=17&rw=8
http://www.discounttiredirect.com/di...r=5&wd=17&rw=8
http://www.discounttiredirect.com/di...r=7&wd=17&rw=8
http://www.discounttiredirect.com/di...r=9&wd=17&rw=8
#474
Not with this particular wheel.
http://www.discounttiredirect.com/di...r=3&wd=17&rw=8 (the Black, black rock Alum)
would be my pick.
Couple questions:
1. Would this still be good for a tire up to 12.50 if i ever decide to go that route and will it look buldged out?
2. Whats the difference between the 0 offset or -6mm offset? (as the tucked look of the stockers bugs me) not sure which/how one of the noted offsets would change this.
sorry for all the questions
#475
Sponsoring Vendor
Trying to keep the weight down and wanna stay Alum. If i decide to do just the wheels(and black is what im looking for)
would be my pick.
Couple questions:
would be my pick.
Couple questions:
2. Given both wheels are the same width the -6mm offset wheel will sit out about 1/4" further than the 0mm offset. Generally speaking, lower offsets push wheels out, higher offsets tuck them in.
#476
1. A 12.50 will work with the 17x8" but an 8.5" or 9" wide wheel would really be ideal for this wide of a tire.
thanks again for all the info!
#477
Just finished installing my 35" BFG KM2's on 15" matte black MB72's tonight. Thanks Discount Tire for the excellent service and an awesome deal.
I know who I'll be calling when we want new tires for the wife's Sahara!
Ran out before dark and grabbed a couple quick pics with the iPhone:
#479
Sponsoring Vendor
Thank you for your support
#480
15x8 MB72's and some 33-12.50 DuraTracs, on N'tl Topless Day, were meant for each other!
This last pic, I didn't even edit the rotation...that is the way it was taken by the brave photographer, who tripped and fell at the last minut, as I had a full head of steam brewing, coming out of that ravine... accidents can happen, luckily, just some bruised pride, but what we do is dangerous, and the spectators/photogs MUST always be aware of what's happenning, and how NOT to be put in this position!
Thanks DTD!
Thanks DTD!
