15" Alloy Wheels VS. 15" Steel Wheels
Old 04-26-2011, 02:37 PM
  #441
Ruckus99ss's Avatar
Anyone do theses on an auto with stock gearing? If so hating life? I'm holding back due to this fear
Old 04-26-2011, 09:01 PM
  #442
xerofall's Avatar
No problem with my setup... I go 60-80 mph daily for work and back.
Love my wheels and tires...
Old 04-27-2011, 05:38 AM
  #443
George F.'s Avatar
Originally Posted by kliff
Right at a 1000 miles on my DT 33x12.50-15's and MB72's with no issues at all. 25psi all around for street, 0-80, and anywhere in between, smooth s silk. Torque @ 105lb/ft, checked after 100 miles and at 1000.
If you got a wobble, I'd say a 're-torque" is due.
Agreed- that is standard procedure and I set torque to exactly that when I installed them originally, then after ~50 miles. I re-torqued also after the first re-balancing attempt was made. That was not my issue here-
Old 04-27-2011, 09:27 AM
  #444
Ruckus99ss's Avatar
Originally Posted by Wilky
Which setup are you referring to?? That's a broad question...
as far as mine (see signature below), well........it's driveable. I'm getting right at 16mpg mixed city/hwy.
35s bfgs with wheels advertised
Old 04-27-2011, 10:17 AM
  #445
wmcvey's Avatar
Do you have a lift ? What size if so ?
Old 04-27-2011, 02:37 PM
  #446
kliff's Avatar
Along with the "which package?" responce....which stock gearing are you referring to?
3.21, 3.73, 4.10, it makes a difference.
Old 04-27-2011, 03:14 PM
  #447
Fenrir's Avatar
Originally Posted by Discount Tire Direct
The BFG mail-in rebate is a bonus to the $50.00 wheel discount and $50.00 JK member discount for purchasiong 5 tires.
Thanks for mentioning this
Dang... I didn't know there was a forum discount! I just bought (5) 285/70/17 BFG AT's...
I'm waiting on 17" MB72's in black. Apparently they're on back order till Mid May? In the mean time, I'm avoiding full turns as not to rub
Old 04-27-2011, 03:19 PM
  #448
Sponsoring Vendor
Discount Tire's Avatar
PM me your name and phone number, If you ordered online I should be able to check on your order to see if you received the discount.
Thank you for your support!
-Travis
Old 04-29-2011, 04:42 PM
  #449
Black 08 X's Avatar
Thank you for your continued support and patience
Well I balanced the two new tires today and they took 7oz of weight. They said its a little much. My wobble now starts at 40mph. My jeep was at firestone for 7hrs today while they kept rotating the tire on the rim to try and make it better. Waiting on mitch to call me back. Im really starting to doubt the duratracs and the 15in black rocks. Theres so much weight on the rims that it hits the brakes.
Old 04-30-2011, 04:45 PM
  #450
wmcvey's Avatar
Are you running with BlackRock wheels or MB wheels ?
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
