15" Alloy Wheels VS. 15" Steel Wheels
Old 04-22-2011, 05:49 PM
  #431
Black 08 X's Avatar
Originally Posted by Discount Tire Direct
Just responded to your PM
We have no known balancing issues with this tire or wheel. Keep us posted on this.
It maybe something suspensin related.
Have anything in mind? I know my track bar is torqued to 125. It only does it at 40mph-55mph. Also it never happened before the new set up.
Old 04-22-2011, 08:31 PM
  #432
ke5rto's Avatar
Well, Matt I got the Chaos 5 wheels in and here they are mated with the Falkens I got as well:
Old 04-22-2011, 08:52 PM
  #433
rubi08unlimited's Avatar
Originally Posted by Mastiff
Here's some before after pics. They stick out a little further than expected, but not terribly. I think I'll need to address the rock rail clearance in the rear pretty quickly here. Anyone have a pic of how they cut it?
Attachment 152727
Attachment 152728
Attachment 152729
Attachment 152730
Attachment 152731
Are you running any spacers with your coils? it looks like you've got some sag in that rear end, almost a reverse rake?
Old 04-22-2011, 09:38 PM
  #434
Mastiff's Avatar
No. I noticed that in the pic too. I don't see it in the before pic though. Maybe just to do with where it was parked for the pic. I'll investigate more tomorrow.
Old 04-23-2011, 01:40 PM
  #435
Black 08 X's Avatar
Well I got my tires road force balanced today and found out two are out of round. Got two new tires coming in on wednesday then I'll try it again. Went ahead and got the lifetime balance so I can go as much as I need. Really appreciate the customer service so far.
Old 04-25-2011, 08:39 AM
  #436
Sponsoring Vendor
Discount Tire's Avatar
Attachment 152823
Love it!
This thread rocks
  #437
Sponsoring Vendor
Thank you for your continued support and patience
Old 04-26-2011, 10:37 AM
  #438
George F.'s Avatar
I got all 5 RoadForce balanced today. The wobble is completely gone now.
May I suggest a hypothesis? Is it possible that non-hubcentric wheels lead to problems with a traditional balancing machine?
These local guys used the hubcentric rings DTD sent on their Road Force balancer after failing to successfully balance them WITHOUT the rings on a traditional balance machine. Now with the rings and using Road Force, they balanced them and no run-out or out-of-round issues were found.
Given the few hours of my time and the additional cost to DTD, might a recommend all of these are balanced the first time with Road Force and hub-centric rings? It seems like it would save time and $$$ in the long run.
Old 04-26-2011, 02:11 PM
  #439
kliff's Avatar
Originally Posted by George F.
Is anyone else having trouble getting these balanced? 33x12.5 r 15 Duratracs on the MB72s. I have a speed dependent tire wobble at ~40mph. The static stick-on weights got pulled off by the tie rod ends when originally balanced by DTD. DTD was straight up with me on the issue and paid me to get them rebalanced but due to the clearance issue, my local shop had to put pound-on weights on the inside lip... DTD even sent me the mounting hub-centric rings to eliminate that variable .... but I still have the shimmy at 40mph. Bad Duratracs?
I had zero tire wobble issues on OEM wheels/spidertrax/33" duratracs on 18's. Frustrated.
Right at a 1000 miles on my DT 33x12.50-15's and MB72's with no issues at all. 25psi all around for street, 0-80, and anywhere in between, smooth s silk. Torque @ 105lb/ft, checked after 100 miles and at 1000.
If you got a wobble, I'd say a 're-torque" is due.
Old 04-26-2011, 02:15 PM
  #440
kliff's Avatar
Attachment 152727
Attachment 152728
Attachment 152729
Attachment 152730
Attachment 152731
Looking good mastiff.
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
