15" Alloy Wheels VS. 15" Steel Wheels
Old 04-21-2011, 08:57 PM
  #421
rubi08unlimited's Avatar
not sure if its been mentioned but the baseline for both packages would be $50 cheaper through the end of the month with the $50 rebade from BFG.
$50 disount to forum members
$50 off on alloy wheel purchase
$50 rebate
= time to buy a new setup!
can you upgrade to the 38x14.50r17s for the same price
Old 04-21-2011, 09:17 PM
  #422
Mastiff's Avatar
$50 rebate
Not sure if I got the $50 from BFG. Is that a mail-in thing, or instant?
Old 04-21-2011, 09:23 PM
  #423
http://www.discounttiredirect.com/di...ns.do?pgid=453
purchase had to be made between april 17th and the end of the month. rebate is mail in.
Old 04-22-2011, 07:55 AM
  #424
Sponsoring Vendor
Discount Tire's Avatar
The BFG mail-in rebate is a bonus to the $50.00 wheel discount and $50.00 JK member discount for purchasiong 5 tires.
Thanks for mentioning this
Old 04-22-2011, 08:34 AM
  #425
Owl
Owl's Avatar
Matt,
Might as well try a direct quote:
5 ea. - BFG Mud Terrain T/A KM2 35 / 12.50 / 15 (38244)
5 ea. - MB Razor 15X8 5-127-19 BMF (49390)
Thanks
Old 04-22-2011, 08:37 AM
  #426
George F.'s Avatar
Is anyone else having trouble getting these balanced? 33x12.5 r 15 Duratracs on the MB72s. I have a speed dependent tire wobble at ~40mph. The static stick-on weights got pulled off by the tie rod ends when originally balanced by DTD. DTD was straight up with me on the issue and paid me to get them rebalanced but due to the clearance issue, my local shop had to put pound-on weights on the inside lip... DTD even sent me the mounting hub-centric rings to eliminate that variable .... but I still have the shimmy at 40mph. Bad Duratracs?
I had zero tire wobble issues on OEM wheels/spidertrax/33" duratracs on 18's. Frustrated.
Old 04-22-2011, 01:09 PM
  #427
Black 08 X's Avatar
Having the same problem right now. Went and got them rebalanced today but still wobbling around 40mph.
Sent from my DROID2 using Tapatalk
Old 04-22-2011, 02:48 PM
  #428
Sponsoring Vendor
Originally Posted by Owl
Matt,
Thanks
Just responded to your PM
We have no known balancing issues with this tire or wheel. Keep us posted on this.
It maybe something suspensin related.
Old 04-22-2011, 03:52 PM
  #429
Mastiff's Avatar
Here's some before after pics. They stick out a little further than expected, but not terribly. I think I'll need to address the rock rail clearance in the rear pretty quickly here. Anyone have a pic of how they cut it?
Old 04-22-2011, 04:47 PM
  #430
Owl
Owl's Avatar
Attachment 152727
Attachment 152728
Attachment 152729
Attachment 152730
Attachment 152731
Yep, pinch seam and rail cutting time. Real easy.
- Remove the rails (one at a time).
- Cut the pinch seam at an angle.
- Paint the pinch seam where it was cut.
- Remove the bottom push tab (plastic) from the rail, at the rear end of the rail.
- Pull the plastic cap.
- Cut about 1 1/2" off the rail and drill a new hole for the push tab (line it up and measure).
- Paint the cut portion of the rail and the hole drilled.
- Install the cap and push in the push tab.
- Re-install the rail.
Very easy (i.e....if I can do it, anyone can)
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
