15" Alloy Wheels VS. 15" Steel Wheels
#1791
Sponsoring Vendor
As for orders shipping to Canada, we do charge a flat rate Customs FREE for tires and wheels. The charge for wheels is $50.00 each and for LT tires, $60.00 each.
#1793
New to the forum, thanks all for the details! Ready to pull the trigger on wheels/tires for my 2008 JK, at the moment it's completely stock.
I need some help, the guy at the local DT store claims: 1. 15's will not fit on any JK (this thread makes me confident he's wrong); and 2. 33's will not fit on JK's @ stock suspension.
Here's the setup, just need the OK from DT that it will fit and will not rub (remember, at the moment no lift, BB, leveling, or spacing):
Thanks in advance, and forgive the forum noob.
- Level 8 Tracker 15x8 (do i need -30mm vs. -19mm?)
- BFG KM2 33x12.5R15 (or 33x10.5R15 if the 12.5’s increase likelihood of rubbing)
#1794
Sponsoring Vendor
The guy at your local store is mistaken. Most 15-inch alloy wheels fit the JK and you can run up to 33-inch tall tires stock. Our apologies for the confusion with that.
The purposed set-up you noted with the -19mm offset and the 33x12.50R-15 will bolt right up, but you will have some rubbing on the lower bumper valence. This can, however, be easily trimmed. If you do not want to trim anything, the 33x10.50R-15 is they way to go.
PM coming your way.
#1795
Hey DT!
Can I get a quote on a set of 5 15" Level 8 Trackers -19 offset and 5 BFG AT's 33x12.50r15 plus any lugs, rings, stems etc that will be needed to mount this setup
Shipped to 48060.
thanks!!
Shipped to 48060.
thanks!!
#1796
Sponsoring Vendor
Thank you for giving us the opportunity to serve you, VWal! Just replied to your PM; thank you for your patience
#1797
#1798
Sponsoring Vendor
Welcome to JKF, d.goods! We appreciate the opportunity at your business.
PM coming your way.
PM coming your way.
#1800
Sponsoring Vendor
Update: here's the final set up 15" Level 8 trackers (-19mm offset) + BFG MT's 33x12.50R15 . . . looks/fits/performs amazing with NO rubbing and no need to trim whatsoever. Attaching before and after shots. Thanks to Matt on this forum and TC, the sales dude at DT Direct who helped:
Attachment 668801Attachment 668800.
That's what we like to hear
Thank you for sharing and for choosing Discount Tire! We appreciate the shout out too.
