15" Alloy Wheels VS. 15" Steel Wheels
Old 02-13-2014, 04:04 AM
  #1651
skunk709's Avatar
Hello DT! the noticed 15" Black Rock D-window are -12mm offset instead of the more common -19mm, i understand they fit over the brakes, but i assume there are no issues with a 33x12.5 mounted?
Thanks!
Old 02-13-2014, 06:00 AM
  #1652
AlexjeepVb's Avatar
Originally Posted by Mangrove Mafia
This damn weather in the east/Midwest has delayed my shipping by a day Question that I thought of today... Has anyone mounted a 35x12.5x15 on the stock carrier? Got kind of worried today that it might not fit.
Im running one on mine. Fit was fine, I did make sure that I made extended bumpstops to make sure that there is no movement to try and prolong tailgate and hinge life.
Old 02-13-2014, 06:35 AM
  #1653
Mangrove Mafia's Avatar
Have any tips on how you extended them?
Sent from my iPhone
Old 02-13-2014, 09:28 AM
  #1654
Sponsoring Vendor
Discount Tire's Avatar
Thanks!
You are correct. If you're on stock suspension though you will have some rubbing on the front valence.
Old 02-27-2014, 09:24 PM
  #1655
jrutola's Avatar
I have a question for Discount Tire, or anyone for that matter. On my 08 JK, I am looking to run the 15" Level 8 Tracker, -30mm Offset. I was told by a member of another forum, as well as a friend, that I should not do this as it puts a ton of stress on the Axles? Basically they said that I am likely to snap an axle. I seriously doubt this, but I am gonna pull the trigger on Tires and Wheels when I get my taxes back so any input would be nice.
Wheels:; 15 Level 8 Tracker
Tires: 33" Goodyear MT/R Kevlar
^Thats the setup I want.
Old 02-28-2014, 09:58 AM
  #1656
mas7269's Avatar
can i get a quote on 5 level 8 trackers black 15x8 with -19 offset and duratracs 33x12.50x15?
is anyone able to tell me exactly how far they stick out past the fenders on a stock jk sport?
am i able to get the mounted and balanced with the tpms installed before they're shipped?
do you offer instillation kits with black lug nuts and extra for the spare? its okay if i have the buy a kit that has extra and do you offer any that dont require a key?
i've never used hub rings...are they something i should be considering?
Old 03-10-2014, 11:54 AM
  #1657
tcfennell's Avatar
Can I get a quote on 5 of the 15x8 -12mm Black Rock D-Window Alloy Full Matte Black with 35x12.50R15 BFG KM2? Also will these RIMs work with a drag link flip, they will be going on a 2008 JK with a 3.5 inch lift?
Thanks
Old 03-10-2014, 03:17 PM
  #1658
Sponsoring Vendor
We apologize for the delayed responses here! I'm not sure how we missed these so thank you for your continued patience
I have never heard of low offset wheels snapping an axle on the JK. Lower offset wheels can create more stress on the wheel bearings but I haven't seen anyone running these wheels (ET-19 or ET-30) have an issue.
PM coming your way.
Thanks
PM coming your way.
Old 03-14-2014, 07:36 PM
  #1659
SmacJK's Avatar
If I have a ton of questions is it best just to PM?
Old 03-15-2014, 07:32 AM
  #1660
Sponsoring Vendor
If you have a lot of questions your best bet is to contact us over the phone. Give TC a call at 1.888.459.4080 ext 51826 and he would be happy to assist you. TC has a lifted JKU and knows the fitments well. Just make sure you let him know you are a member here
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
