15" Alloy Wheels VS. 15" Steel Wheels
Old 09-15-2013, 09:34 PM
  #1561
bbertram's Avatar
5x 35x1250x15 ProComp Extreme MT2
5x Level 8 Tracker wheels
black lug nuts for 5 tires
and
5x 35x1250x17 ProComp Extreme MT2
Going to 58329, thank you.
Old 09-15-2013, 09:42 PM
  #1562
karls's Avatar
Originally Posted by Shane75
I'm running into this issue. The tire shop I went to said they were having trouble balancing with sticky wights due to the closeness of the caliper with my 15" MB72 wheels. I can see one wheel had all of its weights fall off with normal street use. Just a noob question, when hitting bumps in the road, the brake caliper doesn't move at all right? What about at full turns? I might just ask them to see if sticking wights on the outside of the wheel is a possibility.
Now I see why a lot of people running 35's run a 17" wheel.
It's a matter of where they place the weight inside the wheel. If they put it in line with the caliper then yes- you'll lose them......I did. My solution (not recommended) was to shave the weights down to fit under the calipers. Well....as you can imagine, that throws off the balance. I did it a couple times before just having them put the weights on the lip.
If they move the weights out of line with the caliper then you'll be just fine- I was on the wheels where they didn't contact the calipers.
Sent from my DROID4 using Tapatalk 4
Old 10-10-2013, 11:55 AM
  #1563
Sponsoring Vendor
Discount Tire's Avatar
Right now the 15" Level 8 Tracker is $50.00 off instantly when you purchase a set of 4. These are in stock and ready to ship. Level 8 Tracker custom rims
Old 10-16-2013, 06:23 PM
  #1564
8000ft's Avatar
KCM XD Enduro's in a 15x9 with a 4.5" backspace fit with about 1/4" clearance on the calipers and tie rod. I wrapped them with 33x12.5 GY Duratracs, no lift.
Old 10-22-2013, 02:48 PM
  #1565
Sponsoring Vendor
We added another 15x8 ET-19 wheel model to the line-up! Check out the link below for more details.
Details: Level 8 Punch
Old 11-11-2013, 09:05 AM
  #1566
Cgflyer's Avatar
Originally Posted by Cgflyer
DT, can you explain the difference between the Level 8 Tracker 15x8 5-127 -19MTB and the -30MTB. I know that we're talking about back spacing, but can you tell what they convert to in inches? Which will tuck closer to the vehicle. I don't like the super wide stance look. Thanks.
. DT can you tell me what the 19MM converts to in inches for backspacing? More or less than 5.5"?
Old 11-11-2013, 10:21 AM
  #1567
Sponsoring Vendor
The 15x8 ET-19 Tracker has 3.75" of backspace. Check out this write-up we put together on offset and backspace
Wheel Offset and Backspace - How Do They Relate? | The Squealing Tire
Old 11-11-2013, 10:30 AM
  #1568
Cgflyer's Avatar
Originally Posted by Discount Tire
The 15x8 ET-19 Tracker has 3.75" of backspace. Check out this write-up we put together on offset and backspace Wheel Offset and Backspace - How Do They Relate? | The Squealing Tire
Awesome, thanks for the info
Old 11-11-2013, 10:55 AM
  #1569
Sponsoring Vendor
Glad we could help!
Old 11-22-2013, 03:38 AM
  #1570
Saharaunlmtd's Avatar
I bought some 285/70R17 DuraTracs from you guys in July and though I love the tires, I think I'm ready to go bigger. Could I have a quote for the following to 15239?
5 x 35/12.5R15 Goodyear MTR
5 x 15x8 MB Razor
Black lugs
Thanks,
Drew
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
