15" Alloy Wheels VS. 15" Steel Wheels
#1561
5x 35x1250x15 ProComp Extreme MT2
5x Level 8 Tracker wheels
black lug nuts for 5 tires
and
5x 35x1250x17 ProComp Extreme MT2
Going to 58329, thank you.
and
#1562
I'm running into this issue. The tire shop I went to said they were having trouble balancing with sticky wights due to the closeness of the caliper with my 15" MB72 wheels. I can see one wheel had all of its weights fall off with normal street use. Just a noob question, when hitting bumps in the road, the brake caliper doesn't move at all right? What about at full turns? I might just ask them to see if sticking wights on the outside of the wheel is a possibility.
Now I see why a lot of people running 35's run a 17" wheel.
If they move the weights out of line with the caliper then you'll be just fine- I was on the wheels where they didn't contact the calipers.
Sent from my DROID4 using Tapatalk 4
#1563
Sponsoring Vendor
Right now the 15" Level 8 Tracker is $50.00 off instantly when you purchase a set of 4. These are in stock and ready to ship. Level 8 Tracker custom rims
#1565
Sponsoring Vendor
We added another 15x8 ET-19 wheel model to the line-up! Check out the link below for more details.
Details: Level 8 Punch
#1566
DT, can you explain the difference between the Level 8 Tracker 15x8 5-127 -19MTB and the -30MTB. I know that we're talking about back spacing, but can you tell what they convert to in inches? Which will tuck closer to the vehicle. I don't like the super wide stance look. Thanks.
#1567
Sponsoring Vendor
Wheel Offset and Backspace - How Do They Relate? | The Squealing Tire
#1568
The 15x8 ET-19 Tracker has 3.75" of backspace. Check out this write-up we put together on offset and backspace Wheel Offset and Backspace - How Do They Relate? | The Squealing Tire
#1570
I bought some 285/70R17 DuraTracs from you guys in July and though I love the tires, I think I'm ready to go bigger. Could I have a quote for the following to 15239?
5 x 35/12.5R15 Goodyear MTR
5 x 15x8 MB Razor
Black lugs
Thanks,
Drew
5 x 15x8 MB Razor
Black lugs
Thanks,
Drew
