15" Alloy Wheels VS. 15" Steel Wheels
Old 08-07-2013, 04:34 PM
  #1551
Cgflyer's Avatar
Originally Posted by Discount Tire
The -19mm offset will not stick out as far as the -30mm offset.
This is a 15x8 with a -19mm offset and a 33x12.50R15:
Looks good. Thanks!
Old 08-08-2013, 02:43 PM
  #1552
Erok's Avatar
Originally Posted by Cgflyer
Your 30's stick out 2.5"?
Just by eyeballing them, it seems about that. Looks great actually, and I'm thinking that's the rears (they appear to stick out further than the fronts but that's just the way the fender flares are offset). So the 19s would stick out a half inch less than that for about an inch total difference.
Also that's with 35" MTR/Ks, 12.50" wide on 15" wheels.
Old 08-08-2013, 02:54 PM
  #1553
Cgflyer's Avatar
Thanks for the info. I'm probably about two months away from making the swap to 15's with 35's
Old 08-21-2013, 02:57 PM
  #1554
duluthjk's Avatar
Can you still get black MB 72's?
Old 08-21-2013, 04:05 PM
  #1555
Sponsoring Vendor
Discount Tire's Avatar
16" only. The Level 8 Tracker replaced the MB72.
Link: 15" Level 8 Tracker for JK
Old 08-23-2013, 02:37 PM
  #1556
bonechief121's Avatar
How much for 15x8 black rock d window alloy full matte black with Goodyear wrangler mt/r Kevlar 35's mounted balanced with matte caps and black lug nuts shipped to 57719?
Old 08-24-2013, 09:28 AM
  #1557
Sponsoring Vendor
PM coming your way.
Old 09-09-2013, 01:05 PM
  #1558
Dr. Sizzle's Avatar
Default 35s?
Got my 15" Level 8 Trackers in aluminum finish, with 35" MTR/Ks. So far they are fairly quiet on the road and damn they look good. Thanks Discount Tire!
You sure these aren't 37s? You going by the size written on the tire or what they actually measure?
Old 09-09-2013, 08:21 PM
  #1559
Erok's Avatar
Those measure about 34.25 under the Jeep. Advertised as 35's. That's why they say MTR/K runs big! I love these tires after 8000 miles. Just balance and rotate very often.
Old 09-14-2013, 01:56 PM
  #1560
Shane75's Avatar
Originally Posted by atuldo
Talking about MB72 but most likely all 15" rims, to be aware - there is very little space between rim and caliper, after the weights are installed,practically none space left so the adhesive (weights) better be 110% perfect,which mine are not,all 4 wheels have very bad weights adhesive and no chance in hell they will survive(some did not survive install...)!!!!!!
I'm running into this issue. The tire shop I went to said they were having trouble balancing with sticky wights due to the closeness of the caliper with my 15" MB72 wheels. I can see one wheel had all of its weights fall off with normal street use. Just a noob question, when hitting bumps in the road, the brake caliper doesn't move at all right? What about at full turns? I might just ask them to see if sticking wights on the outside of the wheel is a possibility.
Now I see why a lot of people running 35's run a 17" wheel.
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
