15" Alloy Wheels VS. 15" Steel Wheels
Old 02-05-2013, 03:26 PM
  #1421
Packman360's Avatar
The level 8 logo on the trackers are they removable like a sticker? What I liked about the mb 72's was the fact that they were just all black.
Old 02-06-2013, 06:31 AM
  #1422
Sponsoring Vendor
Discount Tire's Avatar
It is a sticker on the Tracker 8 wheel not paint. You should be able to take it off with some Goo-Off or a similar product.
Old 02-06-2013, 11:50 AM
  #1423
Erok's Avatar
OK, I am *this* close to ordering some wheels.
If I go with the Level 8 Trackers, do I need to wait for the 19mm offset to be released, or can I go with the 30mm? I'm not sure what the offset even is
Also, is it worth replacing the TPMS if my stock wheels have just 10k miles on them?
Thanks!
EDIT: I keep reading about backspacing (which I get) and offset (which I don't as much), and trying to clarify my question above. Basically... is 30mm just going to stick out more (or less) from the Jeep than the 19mm? Or is it all internal (caliper, etc) clearance we're talking about?
Old 02-06-2013, 02:38 PM
  #1424
OH9JK's Avatar
This simple graphic helps explain offset and backspace
Old 02-06-2013, 05:59 PM
  #1425
Erok's Avatar
As simple as it is, and I'm a visual person, I guess I just want to know if the -30mm is just going to make the stance appear slightly wider on my Jeep than the -19mm. That's how I understand it. But otherwise, the fit around the calipers and suspension clearance shouldn't be a problem?
Old 02-07-2013, 06:37 AM
  #1426
Sponsoring Vendor
Check out this write-up we put together on offset and backspace.
https://www.jk-forum.com/forums/modi...relate-136663/
The 15x8 ET -30 Tracker will sit about 1/2" (11mm to be exact) further out when compared to the 15x8 ET -19 Tracker. Both offsets clear the JK brakes.
As far as TPMS goes, the Level 8 Tracker will accept the factory sensors.
Old 02-07-2013, 09:44 AM
  #1427
Erok's Avatar
Thanks. I thought I understood, and it appears I do It's weird how some concepts can be elusive... I'm mechanically inclined and also an artist, you'd think the visuals would just clear it up. But the math kept messing with me. Anyway, I think I'm going to like the extra 1/2" stance boost, as long as it performs the same.
And with that, I just ordered my wheels and tires through my local Discount Tire contact! 15" Trackers in the silver finish, with 35" MTR Kevlar! Woooo.
Thanks for all the help, and I'm glad to send money to your company. I'll be happy to send more people y'all's way when they ask about the awesome shoes on my Jeep.
Old 02-07-2013, 09:49 AM
  #1428
Sponsoring Vendor
Glad we could help We appreciate your support!
Old 02-08-2013, 02:52 AM
  #1429
Packman360's Avatar
Do you have any pictures of the -30mm offset on a jeep?
Old 02-08-2013, 06:12 AM
  #1430
Sponsoring Vendor
Here are a couple.
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
