15" Alloy Wheels VS. 15" Steel Wheels
Old 10-28-2012, 12:22 PM
  #1281
smitty141's Avatar
Will the factory TPMS work/fit in the MB wheels or others you sell for the JK?? Im not sure if there in the valve stem, or clamp to the wheel. Info please...
Also, what is the biggist tire on a 15 x 8 wheel??
Looking at MB72 15x8 polished with 33-12.5-15 Dura trac's on my 2013 JK 2 door. As of now I do not have any lift, will a 2" BB be enough with that combo?
Thanks Smitty
Old 10-28-2012, 04:13 PM
  #1282
hypeiv's Avatar
Thanks Smitty
yes the factory TPMS work with the MB wheels... they are just quoted in the OP b/c if you mail order them balanced and ready to mount you can't swap in your TPMS without the right tools... if you order them from a local Discount tire, or buy them unmounted from the internet to have installed at a tire shop, they can swap the OEM TPMS into the wheels no problem.
I run a 35x12.5x15 on my 15x8 so you will have no problems with a 33... you most likely won't need a lift to clear 33's (might have to chop your from air damn, worst case you might end up getting a leveling kit), if you want to run 35's you will need to get at least a budget boost.
Old 10-29-2012, 10:19 AM
  #1283
Sponsoring Vendor
Discount Tire's Avatar
Correct, thank you for chiming in.
I'll just add one thing. Yes, it is possible to run a 33" tire without any lift but some modifications are usually needed. A 2" BB or a leveling kit will reduce and sometimes eliminate modifications needed to run a 33" tire as long as your wheels have the correct backspace/offset. (tires are like shoes, some run larger than others.)
Old 11-02-2012, 10:37 AM
  #1284
Comicnut25's Avatar
Anybody ever run 35 13.50 on there MB 15x8 ? Book says no but I want it to say yes
Old 11-02-2012, 02:39 PM
  #1285
Sponsoring Vendor
Go with the 15x10 D-Window alloy and these will look outstanding! (and it will help them wear better than on a 15x8 as well.)
Old 11-02-2012, 03:40 PM
  #1286
ignatius504's Avatar
35 BFG Mud on the polished 15's
Old 11-02-2012, 06:38 PM
  #1287
Erok's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=384724"/>
That looks outstanding.
Old 11-03-2012, 09:52 AM
  #1288
orangedude71's Avatar
So is the pricing in the original message still possible. Seems like 5 35s for 1500 delivered doesn't seem to be viable anymore if I try to build it up with all of the rebates in place. If not, what is the current least expensive way to get into a set of 5 35s at this time.
Old 11-03-2012, 10:14 AM
  #1289
Sponsoring Vendor
Pricing has changed in since the creation of this thread 2 years ago but we still guarantee the lowest out the door price Best way to save is to purchase through our eBay store. Check out this link for more details (promotion ends 11/4!)
https://www.jk-forum.com/forums/spon...s-back-252195/
Old 11-03-2012, 11:39 AM
  #1290
If I wanted to order the wheels and tires through the ebay deal but still wanted them mounted and with sensors, I assume i shoudl order first, then call up and add to the order?
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
