15" Alloy Wheels VS. 15" Steel Wheels
Old 10-19-2012, 07:07 AM
  #1271
Sponsoring Vendor
Discount Tire's Avatar
Originally Posted by ignatius504
What's the difference in lug nuts from the factory style? And do i need the hub ring? Looking forward to ordering this soon! Thanks..
The factory lug nuts are larger in diameter when compared to the smaller diameter lug nuts we sell for the MB72. Your factory lugs will work but the MB72 utilizes a smaller diameter recessed lug hole which means there is a high chance that the face of the wheel around the lug holes will be marred anytime you need the lug nuts removed when using the factory lug hardware. We recommend the smaller diameter lug kit. The cost is only $45.00 and the kit includes extra lug nuts for the spare assembly.
As far as the hub centric rings go, they are not needed but they do make centering the wheel on the hub much easier.
Originally Posted by 5626638
will this MB Wheels 72 15*8 fit KM2 33x12.5? I saw the most 33x12.5 tires require 8.5 width?
The 33x12.50-15 size will certainly mount up on an 8" wide wheel but for optimum wear BFG recommends running this size on wheels that have rim width from 8.5" to 11".
Originally Posted by tljk2007
I'm sure this has been covered but I have always liked 15x10 wheels. I just bought a 2013 sport with 16x7 wheels and I really need bigger wheels and tires. I'm thinking 2.5 lift 33 12.50 15 on 15x10 but I don't here of alot peaple running 10"wide wheels.Will it work???
A 10" wide wheel will work on your application (assuming the correct offset) with 33x12.50 tire's. The assemblies will stick out a good amount so you may experience some tire rub while articulating off-road. The only option that we know to work in the 15x10 size is the Black Rock D-Window (linked below).
Wheel Products - Discount Tire Direct
Originally Posted by demtek9
Will these work? The ebay test fit tool says no on my 09 JKUR, but it has similar specs as MB72s. Looking at these pair with some 35' KM2s.
15X8 5x127 MB Motoring Razor Wheel/Rim
Finish:Black Machined Face
Bolt Pattern:5-127
Offset / Backspacing:-19mm Offset / 3.7 Inch Backspace
Yes it will work for you. The 15x8 ET-19 MB Razor will clear the brakes on the JK without spacers or modifications to the calipers.
Old 10-24-2012, 09:59 AM
  #1272
Sponsoring Vendor
If you've been waiting for a sale.... Wait no more! Its here!
https://www.jk-forum.com/forums/spon...5/#post3267376
Old 10-25-2012, 01:12 PM
  #1273
Comicnut25's Avatar
Hey I want to get 5 of these but couldn't find an auction for that ! Thanks !
Old 10-25-2012, 03:49 PM
  #1274
Sponsoring Vendor
Here you go. Add 5 to cart: 1 New 15x8 5x127 MB Motoring 72 Black Wheel Rim | eBay
Old 10-25-2012, 05:39 PM
  #1275
Comicnut25's Avatar
Thanks ! Sweet deal !
Old 10-26-2012, 09:49 AM
  #1276
toklas's Avatar
just put in my order for mb72 in 15" 5 min ago... they're not here yet!!! oh the agony!!!! time to skootch my chair and pony keg to the front door and wait....
thanks DTD!!!!
Old 10-26-2012, 09:55 AM
  #1277
otservice's Avatar
We've been running the MB72s in 15" for almost year now and the finish has stood up to some abuse and customer service at DT was great at our local - Bellingham branch. Prices and quality service can't be matched.
QUESTION: I'm looking for some 37x12.5x15 Interco TrXus MTs and I know they are around and I know DT can get them. So is there any way to find out for fact a time frame on them and cost if they are readily available?? They'd be coming to the Bellingham store. The fiance wants to get ride of 35s and get some 37s sooner or later.
Thanks,
Nate
Old 10-26-2012, 12:42 PM
  #1278
ignatius504's Avatar
What kind of weights are people using? Stick on? Or Rim style? Thanks
Old 10-26-2012, 12:47 PM
  #1279
Sponsoring Vendor
Thank you!
thanks DTD!!!!
We appreciate your support
Thanks,
Nate
We do not mail order Interco tires but the store in Bellingham should be able to assist you. You'll need to contact that store directly for availability and out the door pricing
We use adhesive stick on weights which are placed inside the barrel of the wheel.
Old 10-26-2012, 01:53 PM
  #1280
Thank you!
Thanks. I ordered the last tire and wheel separately and the tire place used the rim style. I will have them change them. I hate being on a budget and only ordering one tire and wheel a month. LOL.
Quick Reply: 15" Alloy Wheels VS. 15" Steel Wheels
