NEW!! TeraFlex JK Leveling Kit!! $129.99
Sponsoring Manufacturer
NEW!! TeraFlex JK Leveling Kit!! $133.99
#1155200
$133.99
2" front 1" rear
You can run 34" tires with this!
Those are 305/65R18 tires on this new 2009 JK with this kit.
http://www.teraflex.biz/jk-wrangler-leveling-kit.html#
How can you possibly run 35" tires with only 2" on the front and 1" in the back?
I rub on the front now with your 2.5" BB and don't have much room in the back either.
Boss...the JK on their web site has oversized tires on stock rims, hence the need for more backspacing. I'm still running 255/70 R 18 on stock Sahara rims. I just put the kit on a few days ago and have absolutely no rubbing problems anywhere. I'm planning on putting 305/60 R18 on my stock rims in the future and will need 1.25" spacers to handle the extra 2" width of the tires.
Thanks. It just didn't make sense why stock tires/ rims would need spacers. I'm considering this kit as my 3/4" front spacer did not quite get rid of the stock rake, and I intend to stick with the stock tires & wheels.
The reason for the spacer is because in the rear the sway bar end links they send can rub the wheel and tire under extreme articulation. You could get the Currie end links, and this would fix the issue, or you could run spacers. This is the same issue that was on the budget boosts. I couldn't find a picture with the wheel installed, but here you can see how close it is to the brake caliper.
