Bring it!!! The new RS7MT monotube shock from Rancho
Aww yeah!!!
Highly effective in the dissipation of heat, RS7MT shocks are ideal for off-road use, and larger wheel and tire packages. Featuring an integrated dirt wiper sealing system that keeps dirt and debris out, the RS7MT has a hardened piston rod that resists scuffs and corrosion plus an internal rebound bumper to smooth out your ride on any terrain. In addition, the RS7MT reduces fade and provides responsive damping for a better ride on- and off-road.
PRECISE HANDLING AND PERFORMANCEDeflective Disc Valving features digressive, linear or progressive turning based on application requirements for precision handling and performance on- and off-road
STRONG AND DURABLEFeatures a 14mm hardened chrome piston rod to resist scuffs and corrosion, double-welded loops at stress areas, double-strength closure method, and hot form reserve tube
HANDLES EXTREME TEMPERATURE CHANGESLarge 2-in. monotube body filled with all-weather fluid allows for cooler operation, increased vehicle control, and ability to withstand internal temperatures of -40 to 248°F
REDUCES FADEFull-floating dividing piston and high-pressure nitrogen gas maintains constant pressure against the hydraulic oil, reducing aeration and shock fade
SMOOTH PERFORMANCEInternal rebound bumper and shouldered rubber bushings help reduce noise, vibration and ride harshness, while the PTFE-banded piston enhances responsiveness to changing road conditions for an overall smoother ride
THE RIGHT FITDesigned to fit right out of the box, application-specific mounting installs easily with no need for installing sleeves or extra hardware
KEEPS DIRT AND DEBRIS OUTSealing system with integrated dirt wiper helps keep moisture, dirt and debris from being ingested into the shock and contaminating the oil and destroying the internal seal
BUILT TO LASTLarge 46mm fluon-banded piston for consistent sealing between the piston and monotube for precise control, ride and handling; for extra protection, shock boot RS1952 and RS1961 are available for purchase
BOLD APPEARANCEBlack satin finish with distinctive Rancho red logo for an eye-catching look that stands ou
BUY WITH CONFIDENCEComes with Rancho’s Limited Lifetime Warranty and 90-day Performance Guarantee
