Huntsville Alabama / Tennessee Valley Chat
Old 09-19-2010, 02:03 PM
  #5481
08RedRecon's Avatar
Originally Posted by kollinsb
I'm needing a good reliable shop near Nashville (I live in West and work in Nashville) that can install 5.13s for me. I have a 4 door X. I haven't ordered the gears yet but am looking to get this done quickly. Any suggestions?
Thank you in advance.
Check with 4WD in Nashville
4095 B Nolensville Pike Nashville , TN 37211
Old 09-19-2010, 07:52 PM
  #5482
JK-Rubi's Avatar
Chris/Jayson
Bet your daughters would love camping even more if they could spend the night in one of these (not sure how it would handle the rain, which is important given our track record).
Old 09-19-2010, 09:30 PM
  #5483
Denny2565's Avatar
Warped rotor or bent shaft?
I had a bad brake squeak last year and replaced the pads last December. A couple months after replacement, the squeak came back. I didn't worry about it too much because the squeak would come and go. Over the past couple months, the squeak was becoming more persistent so I pulled the tires off to check things out. The pads were fine, so I pulled the rotor off. It had a lot of dirt and debris in it so I cleaned it out and thought that would fix it. On a hunch, I decided to put the jeep in drive and check the rotor rotation.
Here's what I saw:
http://www.youtube.com/watch?v=mMjNc9P9tt4
Old 09-19-2010, 10:55 PM
  #5484
Divescaves's Avatar
Here's what I saw:
I'm thinking your lug nuts hold the rotor on and thats what you are seeing
Old 09-20-2010, 01:24 AM
  #5485
jeepoholic's Avatar
Originally Posted by JK-Rubi
Chris/Jayson
I was thinking of buying it for myself!
Old 09-20-2010, 05:30 AM
  #5486
Denny2565's Avatar
Good point. I'll try this again, but with a few lugnuts on next time.
Old 09-20-2010, 08:39 AM
  #5487
ASTE25's Avatar
I agree, if you had that much runout you'd definatly feel it in the pedal. I have never seen a rotor "warped" that much. It could possably be a bent axle shaft, however, you'd still feel that in the pedal as well.
Old 09-20-2010, 01:51 PM
  #5488
burbingus's Avatar
Originally Posted by ASTE25
Micah, I'm sure you feel his pain.
LOL I just saw that post. Fortunately my new tires are sitting in storage waiting for the lift application
Old 09-20-2010, 02:07 PM
  #5489
ckivy's Avatar
Default bent axle
I have the same issue, and as much as I tried to make myself believe that it was a rotor, or something other than a shaft, that is what I keep coming back to. Chromoly axles are needed.
Old 09-20-2010, 05:58 PM
  #5490
JK-Rubi's Avatar
Default Rear Axle - shaft and flange
Okay, I keep reading posts like this one ----> https://www.jk-forum.com/forums/show...8+pinion+shaft that give the impression that the rear shaft in a D44 is almost indestructible unless one is going airborne with their Jeep. But, here in the South, I keep hearing about folks bending their rear shafts/flanges.
Dumb question time - are they two separate parts, or is it more a matter of semantics where say, the shaft didn't break, but the flange on the shaft is bent out of shape, thus requiring a whole new shaft w/ flange?
If the latter is correct, what help is a chromoly shaft if the flange is the weak point?
Quick Reply: Huntsville Alabama / Tennessee Valley Chat
