Front Bumper Build
#21
OK, I'm trying to put together a build along, so here goes it.
Step One (which should probably be step two in most cases): Look at the available material to make the bumper out of. In this case, I have an abundance of 4x6" 3/16" stock; but, it's not quite as long as the entire bumper, so I'll have to make separate wings.
Step Two: Design the bumper.
This is my quick rendering of what I want it to look like. Since this is a quick rendering, it's not to scale, with no measurements provided.
Step Three: Assuming there are measurements from the designing of the bumper, start making templates of the various shapes out of cardboard. Then trace out the templates on the steel stock with a Sharpie.
Step Four: Cut the shapes out of the steel. I'm using an angle-grinder.
Step Five: Clean up the cuts. Make sure all pieces are equal to their opposite side counter part, and that all corresponding pieces fit together.
Step Six: Clean up the steel. My stock is pretty rough, with surface rust on the inside and a heavy primer on the outside. I want to make sure all the rust and primer is off. Additionally, I want the inside to be primed, or have some kind of rust inhibitor applied to it.
Step Seven: Drill holes.
Step Eight: Test-fit the center piece.
Step Nine: Weld up the shapes.
Step Ten: Clean up the welds. My welds will not be pretty, so I'm going to have to hit them with the angle grinder to make everything look nice.
Step Eleven: Apply primer/finish coat to bumper. I'm not sure what I'm going to do yet. I'm thinking I'll rattle-can it first. Once I get a winch, then I'll probably have it powder coated to match the Expedition One rear bumper.
OK, I just made up all these steps as I've been typing, and as I said before, I've never done this before. The steps will probably change; but, for now, this is my outline.
#23
Ordered my Teraflex spacers and shackle mounts today. I have a pretty busy work week, so I probably won't get back to the bumper until the end of the week. Maybe my new grinder will be here by then.
#24
I shit-canned the Teraflex spacers and shackle mounts because I thought I was buying pairs when I was buying single pieces. I ended up ordering the PJ shackle mounts.
I'm thinking about the Daystar 3/4" spacers, though.
#27
Location: Hangin in the sunshine state....staging forum..
Chris great idea using the cardboard as a template
as far as getting rid of the rust you could coat the steal in Por-15 or get it sand blasted, just sanding it wont get rid of it, it will come back.
#28
