SD Suds & Grub - Fuddrucker's - FEB 26th
#53
They supposedly are roping off an area for parking. Frank will have to touch base with Liquidhigh to make sure he has the updated headcount and they are prepared for us.
#55
Hope you guys can make it down...it is the closest SnG we've had to Long Beach and the OC
Hope you're able to make it and check out all the Jeeps!
Well even though we have a parking section set aside...showing up early is always good. At Gordon Birch we had our own section and then the valets started giving away our spots but there are other lots close if we need to use them
Great to hear you can make it Rick and it's fantastic to see you on the forum! We can talk about the run you are planning...Chad (willypapooh) last run prior to deployment! Hope we can get a good turn out to see him off right!
#57
Parking shouldn't be too much of a problem. The issue we might have is if eveyrone shows up at 6:30 wanting to order food. Showing up early won't hurt. They do have an ouside patio which will fit 40 people. We may need to use the patio and indoor seating for the fair weather peeps
#58
i just spoke to gerald the GM and they are waiting for us. They have abn outdoor patio and it is all ours. There are no heaters but the have tall windows which block the wind. We will also have seating inside. Also make sure you mention you are with JK-Forum to get your 10% discount on food.
#59
