2nd Annual Anza Borrego Newbie Run: October 25th
#151
Yeah, yeah... I know its 2nd Annual. Hopefully since we will not be there on the Jeep Jamboree weekend hopefully there will be fewer people on the trail and we can cover more ground.
#152
My rock rails are actually on my living room floor, since I don't think I can bear the weight to install them alone... without splitting this damn thing open again...
#153
Sponsoring Vendor
Off Road Evolution Rep
Actually its a 1980 JK.... I am typoin like crazy... left thumb is bandaged... took a knife to it the other day... if the bone weren't there to stop the blade, I would be a little lighter on the left.
If you need help getting the rails on I can always lend a hand or in your case a thumb... just let me know. I don't mind
#154
Took out my pocket knife to remove a zip tie from something.... I typically put the blade under the tie, then put more of a rotaional force on the blade to pop the tie so the blade doesn't lurch when the tie breaks... somehow it lurched... and by then it was way too late. And of course I caught the interior, serated part of the blade. Picture cutting a Denny's cheap steak with a crappy Denny's steak knife.
It happened in the parking lot just before a meeting. I was quick to apply pressure and it didn't bleed much, so I contemplated just taping it and going into the meeting.. but when I saw bone, I thought it better to have someone look at it. So I drove from Santa Ana to Long Beach and have it looked at. Stitches would have caused problems with the skin flap, so they used string reinforced strips (kinda like butterfly bandages) and glue.... but it appears to be doing well.
(Bringing this back to something more on topic)... I remember thinking on the drive home about what would happen if this happened on a trail. My trail kit carries enough to deal with this level of stupidity, but not too much more. Makes me wonder if I should bulk up a little on the first aid stuff.
The cut was on the side, so there was no nerve, tendon, or muscle damage.
#155
#156
They need to be on by Anza so I can test the limits of a stock JK. Once on, I don't have to worry about screwing up the body. I don't want to consider having to use the bypasses any more. If I get stuck, I get stuck.
#157
She loves the nature and the people aspects, but not the camping, the trail dust, and the peeing on the trail. She is also reluctant to take the wheel, but has a few times on the street and at Pismo.
She'll do a good job, but since she's so tiny, herc-ing much weight might be an issue. I guess I'll lift and hold, she can get the nuts on.
The rails install looks real easy... but it seems like there's not enough strength in the connection points so support a lot of bashing or hi-lift jack. We shall see. I guess I will have to trust the Mopar thought things through.
#158
Sponsoring Vendor
