No heat 2012 JK
Old Today | 04:50 AM
Josht1189's Avatar
Default No heat 2012 JK
My 2012 Jeep Wrangler will not blow heat. I replace the blend door actuator flush the heater core topped off all the coolant. My heater core seems to be warming up both sides of the hoses. Get warm. Can't figure out what the issue is. Any ideas?
Old Today | 10:21 AM
Jay2013jk's Avatar
Veteran: National Guard
Welcome to the Forum .. Question is any air blowing out of any vents; i.e.. AC out the vents, Defrost on the window? Do you see coolant moving in the Rad once the thermostat opens? DID you Burp your system after the Flush?
Old Today | 03:01 PM
Josht1189's Avatar
Yeah I'm getting cold air coming out the vents. There's no air in the system. Everything's good new thermostat. It's opening up heater cores. The pipes are getting warm like they should so and I replaced the blend door actuators
Quick Reply: No heat 2012 JK
