Front axle/ driveshaft vibration under 20mph
So i just upgraded my steering system, adjustable feont control arms, steering stabilizer and ball joints and after my alignment there’s almost like a grinding slight vibration and it feels like it’s coming from the axle drive shaft area. It only vibrates unders 20mph accelerating and decelerating but soon as it hits 20mph it’s back to normal. I feel like some of the angles aren’t correct on the alignment but wanted to see if anyone else had these issues!
what kinda front DS do you have? factory, double cardan? single? what is your caster angle alignment spec after the control arm install? Caster is one of those things that can be a fine line to straddle with an aftermarket shaft.....want it high, but if you get too high the result gets into driveline vibe areas. also, you could pull that front shaft and take a test drive to be 100% certain it is the DS you are feeling.
not sure what drove shaft probably stock it looks like the caster is 11.0 after alignment
WTH!!! you want caster in the 4.5 to 5 degree range. so y, that axle is rotated way backwards which is creating a weird pinion angle. I mean, you have 6 degree caster built into a factory axle, so at 11 degree caster, that pinion is facing DOWN 5 degrees (11 degree caster - 6 degree that is built in = -5 degree pinion angle).
you have a very extreme setup with that much lift and, assuming, a factory axle. you need to target the lowest possible acceptable caster due to the separation between your TC and pinion. anything over 4 degrees should be fine. the lower the caster is, while still being acceptable, is going to make the stress on the DS the least amount.
okay thank you! Gonna take it to a jeep shop in Destin this week and will report back thank you for your help!!
