No Bass
No Bass
I recently installed the sony XAV-AX4000 from trail seven. It came with the wiring harness and everything i needed. For some reason there is no bass. I have tried everything, changed all the EQ functions checked connections, nothing.
I plugged the old stock unit back in and bass worked fine.
My 17 JKU does not have the amp under the steering column, did not even have Bluetooth.
Do i need to buy an amp or is this a head unit issue? Anyone else have this problem?
