Auto Transmission Cooler O Rings 2012 JKUR
Old Yesterday, 11:21 AM
Eggdashure's Avatar
Default Auto Transmission Cooler O Rings 2012 JKUR
Hi All, I just finished replacing the engine on my 2012 JKUR and at some point along the way, I lost one of the O Rings that goes between the tramsmission lines and cooler in front of the radiator. It's like a metal washer with a rubber gasket on the inside
I went to the stealership and they don't have the washers available separately, just the cooler lines that includes the washers...for $250! Does anyone have a lead on where I could get just washers / O Rings? Looks like the attached Pic but separate washers for each line.
Old Yesterday, 03:53 PM
Veteran: National Guard
Jay2013jk's Avatar
Well, checked my sources and here is the info on the cooler lines = what you seek is made onto the lines:
68003503AA LINE, Oil Cooler Pressure and Return Chrysler
List price is $198 .. work the dealership for a discount, ask what % discount do you sell to IRF (independent repair facility). With the PN you can now search the Net too.
Old Yesterday, 08:36 PM
Eggdashure's Avatar
Yeah, not going to spend $200 for a couple of washers. I ended up making some seals out of a rubber hose. Cut them as clean and straight as I could and it worked. Got me home until I can find proper seals.
Old Yesterday, 09:51 PM
DanB13JKU's Avatar
Almost sounds like replacing the cooler with an aftermarket stacked-plate one would be a better choice. It also looks like Dorman makes the lines - check www.rockauto.com under automatic transmission “fluid cooler line” and see if that is what you need. $82 is a heckuva a lot less expensive.
Quick Reply: Auto Transmission Cooler O Rings 2012 JKUR
