Sitting water created a hole behind rear passenger fender
Old Yesterday, 11:00 AM
isa-gecko's Avatar
Default Sitting water created a hole behind rear passenger fender
Before sanding off all the rust, it didn't look too bad. But after sanding away all the rust I had realized that the previous owner had sealed off the drainage for this spot so sitting water had rusted out it from the inside. It left a hole in the side and a large opening on the bottom. I filled it with an poly-carbonate reinforced fiberglass resin, sanded/shaped it, primed, and painted it. It is barely noticeable anymore and I'm pretty proud of how it turned out.
One image is going to be the spot after I sanded it out - you will be able to see all the holes!!
And the other will be the final result!
Quick Reply: Sitting water created a hole behind rear passenger fender
