Teraflex HD tire carrier for the JK
Old 08-20-2022, 11:18 AM
AliTW's Avatar
Default Teraflex HD tire carrier for the JK
So I got the TF HD tire carrier but I don’t have the provided bolts, will the factory bolts work if not, how can I order the required bolts?
Old 08-20-2022, 11:31 AM
Veteran: National Guard
Jay2013jk's Avatar
Welcome to JKF.. Do you have pictures you can post or a link to the carrier from Teraflex? Contact Teraflex and see if you can buy the correct bolts.
twp (09-23-2022)
Old 08-20-2022, 11:42 AM
AliTW's Avatar
Just attached a pic to the post. I emailed them about it, I don’t have neither the bolts or the washers.
Nozzleweed (08-26-2022)
Old 08-23-2022, 08:29 AM
FSRBIKER's Avatar
I picked up the bolts at Lowe's for my install.
Old 08-27-2022, 06:16 AM
AliTW's Avatar
I didn’t find the required bolts not a single shop has it. Just bought a non flanged hex head M8x1.25 40mm bolt. Don’t know if it fine or should I cut to length of 35mm.
Old 08-27-2022, 08:41 AM
Received 1,944 Likes on 1,701 Posts
You're going into a hollow cavity there so 5mm length difference shouldn't matter much. I would have just reused the originals where possible. Not a huge deal IMO.
Old 08-27-2022, 10:27 AM
AliTW's Avatar
I guess I’ll go for it with washers. Thanks
Quick Reply: Teraflex HD tire carrier for the JK
