2008 JKU LS swap, 40s, everything inbetween
Old 01-11-2021, 03:14 PM
Wallyman424's Avatar
Default 2008 JKU LS swap, 40s, everything inbetween
I'll keep it short. Bought a 2008 JKU with 240k miles on it and am pulling it all apart and replacing with the following:
- Overland performance swap kit
- Crate LS3 480hp
- Crate 6l80e supermatic
- Metalcloak 4link longarm 4.5" lift
- Fusion kingpin Dana 60 front and Dana 80 rear
- Howe hydraulic steering assist setup
- KMC RG race beadlocks
- 40" milestar tires
The victim. 2008 JKU with 240k miles, not in great shape, janky headlights, crappy top... but cheap
First mod. Replaced the peeling steering wheel with a NOS version from a PT cruiser. 90 bucks, and came with cruise control!
Body separated from the frame.
Crap engine coming out.
Ready for the junkyard.
Status post pressure washing and degreasing.
Next up, frame surface rust removal, metal treatment and painting the frame.
Old 01-11-2021, 04:07 PM
TheDirtman's Avatar
Why do a compromised JK kit if doing everything? Go with a custom suspension and do it right.
Old 01-11-2021, 04:21 PM
Compromised in what way? I'll likely redo the suspension in the future, but I figure its a pretty good deal for a good quality kit to get me going.
Old 01-11-2021, 04:25 PM
TheDirtman's Avatar
Using factory location brackets and the poor geometry that almost all the long arm kits have. With the body off the frame is the time to do it since you need to move so many cross members and remove the factory control arm and track bar brackets. Cut the front of the frame off, relocate the steering box forward and up. Hope you ordered 72"+ WMS axles.
Old 01-11-2021, 04:38 PM
Axles are 72". The main reason behind sticking with stock geometry is time. I'm shooting to get this all done by March. Again I'll probably tackle the suspension in round 2 next year or the year after that. Pulling the body off the frame takes a couple hours, no big deal for me to do again.
Old 01-11-2021, 04:58 PM
TheDirtman's Avatar
Ya, it would take like two days to do it right the first time.
Old 01-11-2021, 05:22 PM
Well, even if I don't change my mind, what would you suggest?
Old 01-12-2021, 12:56 AM
2011oscarmike's Avatar
Please do not email asking me to recommend a lift kit or brand
Old 01-12-2021, 04:07 AM
karls10jk's Avatar
Dirtman suggests 4 link calculators and DIY. I've seen a recommendation that GenRight is/ was the least bad at the time.
Old 01-12-2021, 07:14 AM
TheDirtman's Avatar
The Genright Elite kit is worth studying a bit. They still have limited separation in the frame links and I don't the orientation of the upper frame mounts. It does require a fuel cell though so you are likely not going with a double triangulated set up. Typically on a JK kit set up the axle side lower control arm and shock mounts are hanging too low. Move the lowers as wide as you can and up closer to the center of the tube so they don't hang down and it will flatten the lower links for better ride and geometry. French the frame and outboard some 14" 2.0 coil-overs. On the frame side lowers, mount to the outside of the frame and trim the body mount. You will want to keep them close to the bottom of the frame rail and put them as close as you can the the output shaft flange on the transfer case. Mount the frame side uppers as far up on the outside of the frame as you can. On the front clear run a 2.0 coil over. Move the steering box and frame track bar bracket forward and move the steering box up a couple inches. Cut off the passenger side frame front and reconfigure with smaller tubing for clearance on the track bar and drag link. I would try and line up the lower links with the bottom of the frame. Keep the uppers as again as high as you can get them inside the frame. You should be at a 10" link separation on the axles and around 5:-6" on the uppers.
And get some real tires, not the Lite Brite specials.
Quick Reply: 2008 JKU LS swap, 40s, everything inbetween
