B-Pillar repair questions
went out last weekend and kissed a tree...anyone have any experience repairing b-pillars...should i use stud weld dent puller. I think the pillar is welded into place so replacing it is not an option? any help would be much appreciated.
I guess a lot depends on the results you’re looking for: prevent rust and make it presentable, or restore the appearance to factory. It doesn’t look like the damage is too bad, so the stud-weld dent puller would do a fair job, but I can’t tell if there are any creases/hard bends. Those are much more difficult to fix.
If the doors open and shut fine then I think you have time to decide, maybe find a body pro to talk to, as we aren’t unibody, there may not be as much of a structural issue.
My SWAG is you can get most of it out, perhaps by drilling from the inside and tapping out, just use a piece of steel on the outside to beat against if you do, like a bucking bar is used for riveting.
I think you can get most of it out, not all then it’s Bondo, some of that metal is likely stretched is why.
But then I’m no body pro.
