Help. Electrical gremlins jku
Had a new kenwood ddx5707s touchscreen head until professionally installed in my 2013 jku. Also added amp and sub. Everything worked great for about 4 months. Now radio will randomly decide to cut on and off
Already bought new head until to rule that out no change
once it goes off the only way to get it back on is to pull the radio fuse out of the power distribution block for a few seconds then replace. Might work 3 days might work 30 minutes.
have changed negative terminal with a much better one have positive terminal to change out. Help!!! I'm to the point of trading my jeep because I can't figure it out
I've run across electronic devices that lockup with low voltage spikes. Rather than re-boot, or better yet, simply function and ride out momentary under-voltage; they lockup and require a power off reset to reboot.
Here's some potential fixes:
- Intermittent bad connections -- Easy to write, hard to find. "Professional Installers" are often not that well trained.
- Add a capacitor across the constant 12v and neg/ground.
- Ditch the current stereo head unit for a totally different design/brand that hopefully isn't so picky about electrical noise. And it is possible this is a component or design flaw that both of the identical head units have.
