Yes another question about a TF 2.5"..
#52
Q: Are new driveshafts needed after installing a lift?
A: You really should consider installing a new rear double cardin U-joint style drive shaft if you have lifted your Jeep JK Wrangler 3" or more and have a 2-door. This is needed because the short rear drive shaft of the 2-doors will be at a steep enough angle that the CV boots will wear out prematurely. However, in order to do this, you will need to buy a set of rear adjustable upper control arms so that you can properly set your pinion angle. 4-Door Unlimited models do not have this problem as their rear drive shafts are very long and a lift will not effect the angle of it too much. As far as the front goes, if you have an automatic transmission, you will need to replace the drive shaft with a double cardin U-joint style unit as well as the diameter of aftermarket shafts will be considerably narrower and will not come into contact with the transmission and/or skid plate. Failure to do this will result in the tearing of the factory drive shaft boot as it makes contact with the transmission. Manual transmissions will not have this problem and keeping the factory front drive shaft will not be a problem.
#53
#54
Just a couple of quick facts that apply to 2 and 4 door models
1. TF is a better more complete kit.
2. Wheel spacers are not the devil
3. you will NOT have driveline issues! Only "maybe" would be an automatic front shaft hitting the skid.... nothing a cutwheel can fix in 5 minutes
Do it
Do it
1- indeed
2- Entry recorded.
3- take a look at the FAQ.. he said the opposite. FAQ: " You really should consider installing a new rear double cardin U-joint style drive shaft if you have lifted your Jeep JK Wrangler 3" or more and have a 2-door. "
With 2.5 am I just too close or am I safe ? .. is there a "gray zone" somewhere or 3" is the start of the "gray zone"... ?
#55
I won't tell you what to do or not to do but here's what I would do...
The 2.5" TF with coils will give more than 2.5" I own a 2dr and if I was to put this on my rig would I run out and drop $400 on a new driveshaft right away? Nope. Would I keep and eye on it and start saving up for one eventually? Yes
#56
#57
You're doing the exact same thing. I am doing my 33" tires first though. I also have 3.21 gears in my rig. And found out that my VIN says "F" on the 4th character but my dealer says my Jeep has the HD shocks?
So... I will probably get the coil spacer with new shocks. Its enough to run 35" tires and I can always add a 1" body lift later.
#58
