Yes another question about a TF 2.5"..
Ok here's the 'lil story.. I've ordered a 2.5" RC BB but for unknown reason, they have lost my order somewhere. (!!!) So now i'm looking somewhere else and maybe for the TF 2.5" with coil and shocks. No spacer or relocation bracket.
Now here's my question.. Why the 180$ kit that I was trying to order at first time from RC come with coil spacer, shock relocation bracket ( ok for both..) BUT they include it their cheapest kit "Serie II"; brake line brackets, rear track bar brackets and rear sway bar links.
The kit that i'm looking for right now is the "JK Wrangler 2.5” Lift Kit with shocks and coils" doesn't included (or maybe i'm wrong..) front brake line brackets and front sway bar links..
Also.. both kit doesn't include front sway bar links. Do I need them too ?
In other words.. Do I need to order something else if I bought the "JK Wrangler 2.5” Lift Kit with shocks and coils" ?
RC BB:
TF 2.5:
Need advice !
Thanks in advance !
RC BB:
TF 2.5:
Need advice !
Thanks in advance !
As a DD mostly used on road JK.. What should be the best choice ?
1- Coil spacer and oem shocks with bracks
2- Coil spacer with TF Shocks
3- New Coil with oem shocks + bracks
4- New Coil + New shocks
mostly on road and DD JK in mind..
Thats my actual dilemna..
Or if any of those choice are the better one IN MY CASE.. can you suggest me something ?
If I had to do it again I'd do the front adj control arms (at least lower??) at the same time so you can set your caster higher. If you don't, it will still drive but especially on highways IMHO it will drive like sh$t
With your caster increased (and nice handling and ride) you might find as I did that the front stock bumper rubs on turns where there's some flexing. So then a front bumper solution would be in order......
And if you're getting a new after-market front bumper, might as well get a winch.....
And so on....and so on....
My concern with the TF 2.5 kit is that it will give more than 2.5" of lift and screw up the driveshaft angles. I went down that road with my Cherokees and it was not a pleasant journey.
I am trying to figure out what lift I would go for. I am running a 2 door X with HD shocks. I do plan on keeping 33" tires for a long while but if I get a bonus at work, 35s might not be far off.
After all, I use my JK as a DD without any serious offroading and dont really need flex. Just some mudding. Is there any difference ( except price..) between coil spacer and new coil ? Same question for TF shocks ( those included in the kit) and OEM shocks with a relocation bracket ?
Did you notice a higher lift than ±2.5" like other have said before ?
Don't want any driveshaft problem or stuff like that.
I want to do a "SAFE" lift since its my DD.
Some coil spacer will assure that the lift wont be higher than 2.5" right ?
So coil spacer + new shocks sound good or you stick with #4 anyway?
