YAY I fixed my Death Wobble!, thank you planman!!
Forum Tech Advisor
The steering stabilizer interferes with finding the root cause.
It's like a GYN doing a breast cancer screening on a woman wearing a ski parka.
Say the problems are loose front trackbar bolts that have ovaled out the front trackbar bracket bolt holes, damaged the trackbar bushings, and damaged the drag link end on the knuckle side. The steering stabilizer only buffers movement in the tie rod. It does nothing to prevent further damage to the trackbar bracket.
There are plenty of pics out there of JK owners who did what you asked about and ended up ripping the entire frameside trackbar bracket completely off the frame at freeway speeds. They are luckily they didn't cause an accident or roll their vehicle.
It doesn't take weeks to figure out the root causes of DW. In most cases, it takes less than an hour. In complicated cases, it could take about 2 hours.
A vehicle with DW should absolutely not be driven until it is fixed.
There's a lot of things that can cause a DW if you bent your tie rod and messed up your toe can cause it for example. Balljoints is another. Another problem I see is budget boost lifts in general. No adjustability and camber being out of whack, which cause stress on parts and make them go bad like drive shafts and balljoints.
The steering stabilizer isn't the cause.
It fails when it can no longer mask the cause.
If all a person does is install a new steering stabilizer and not actually fix the cause(s), then the new steering stabilizer will fail prematurely as well. In the meantime, the cause(s) will get worse.
