XRC Gen 2 Bumper lighting
Hi all. I have the smittybilt xrc gen 2 rear bumper and tire carrier. Finally decided to tackle the led lights for the rear. As you may know, smittybilt instruction are the worst around. All I have is a wiring diagram. I can figure out the wiring I think, but where do I mount the control box bracket? Also, is there an existing spot where I run the wires from the rear to the inside of the jeep. Anyone with experience with this, please chime in. I'll even take pointers with the wiring if Ya got it.
So the diagram show wiring if you were connecting them as daytime running lights. Just follow that for the wiring.
The Yellow wire you can connect to the reverse light wire.
The Red wire you can connect to a switch or relay to 12V.
The Black wire goes to vehicle ground.
There is a ton of room behind the tail light and I would recommend just tiewrapping the control box in there.
