Xenon or Bushwacker
Old 06-29-2010, 07:03 AM
  #71
RichRock's Avatar
Originally Posted by sahara-07
i am in quebec canada and i did not put theme on .
did you get the lights fixed? mine seem to work ok so far.
Old 06-29-2010, 07:05 AM
  #72
JK-Forum Founder
wayoflife's Avatar
Just installed a set of Bushwackers on our orange JK and this is what it looks like...
Old 06-29-2010, 07:10 AM
  #73
zuba's Avatar
That's my next up grade next week
Old 06-30-2010, 07:36 PM
  #74
sahara-07's Avatar
yes they are working fine now
Old 06-30-2010, 08:38 PM
  #75
RichRock's Avatar
Well I got the back ones installed yesterday and I am very pleased with the results. I did have to remove my gas cap cover, but it went back on over the fender with no problem.
I only found a couple of glitches in the instructions, nothing major. There is a slotted plastic cover in the front wheel well that you are supposed to remove and reuse later before you take off the stock fender/inner splash shield. The instructions tell you to reinstall it, but failed to warn me to take it out in the first place, so it's torn up. Probably will just stick some goop on it and replace.
Also re the side marker lights. The instructions say to install with the supplied screws, WASHERS, and nuts, but there are no washers. They are not listed in the parts list either. But it seemed to go well enough without them. Other than a couple times where the number of fasteners in a pic didn't match the text, everything else was very accurate. Certainly better than most instructions, and the pics were very helpful.
I was a little nervous about tearing into my stock fenders, but now that it is done I think these are better looking and better quality.
BTW don't bother trying to sell your stock fenders on craig's list. They will be trashed when you finish. You can salvage the old marker lights, but without the wiring.
Old 06-30-2010, 09:23 PM
  #76
centerfieldr162's Avatar
River Raider!!
ID:	75044   Click image for larger version
Old 01-03-2011, 03:11 PM
  #77
knight1000's Avatar
bump, for any new flare pics.....anybody?......anybody?
Old 01-03-2011, 03:41 PM
  #78
i'm confussed - the bushwacker guy at the quadratec show said you dont have to cut anything they go right on and you guys say you have to cut
Old 01-03-2011, 03:48 PM
  #79
JK-Forum Founder
wayoflife's Avatar
you only have to cut if you want to retain your factory fender pants. if you're cool with just yanking them out, no cutting is required.
Old 01-03-2011, 03:51 PM
  #80
your sayin yanking you mean just pull them off and break the so call christmas trees off ??
Quick Reply: Xenon or Bushwacker
