Wtf?
I'm just finishing installing the 2.5" TF lift kit on the rear end, and i read that you have to tighten the control arm bolts with the weight of the vehicle on the ground... I don't understand how the hell im supposed to tighten the axle end bolts to 125 pounds... I can barely get a wrench in there... there is absolutly no room... an i missing something?
He is right, the instructions say to loosen the lower arms during the instalation. And the control arms and the track bars are all tightened to 125lbs (I would suggest going up to 140ft/lbs). And there is no easy way to do it. Get on your back weasel your way in there and tighten away!!!!!!!!!!!!!
![Cool](https://www.jk-forum.com/forums/images/smilies/cool.png)
The teraflex instructions stat to loosen, but not remove the rear control arms... I don't get it really. I'm not thrilled with this teraflex kit, it was missing a bolt, the trackbar bracket is a mile off and requires boring out the holes to make it work,and the instructions are lousy..... I'm just going to take my wheels off and tighten the bolts back up.
yeah its stupid... they tell me to loosen the arms, then install the bump stop extensions... which get right in the way of tightening the arms back up.. what a crap set of instructions.
