Worried my mods will kill my gas mileage
#21
I believe Jeep's website has the option to check out gear ratio under the 'owners' tab. 3.71 should not have a problem, but any weight/resistance added to a Jeep that is already not aerodynamic will just increase the problem more. Also heavier tires have a significant impact, I have Nitto Trail grapplers and they are a drag on the road, wish I went with something lighter.
Also a programmer, i.e. flashcal, will help get everything in order for performance.
#22
I wouldn't worry about it. Stock with a manual, I was getting 18mpg. With 35 and no other changes, it dropped down to 16.5 mpg. Today with 38s I am getting 13mpg. I can't wait to see what I get after I install the super charger . At this point there is no need to worry.
#23
Thanks guys. Who needs a mechanic when I have all of you. I will look into getting a programmer and playing around with it. Next week I will be installing Gibson Cat-Backs. I see a lot of money being spent. Thanks again
#24
Hey... I was helpful. or perhaps just a bit depressing.
#25
Hey worth mentioning for anyone else who might be reading this. The biggest hit on your MPG will be the unsprung weight of the wheels. Even when people say 35's. I have seen rims 17x9, that range from 26lbs - 37lbs. Same for tires, 58lb for general grabber AT's versus 75lb falkens.
So, if someone says... I have blah blah blah power on 35's. It helps to know tire brand, size, and same for rims. Static weight aint that big od a drag as having heavier wheels.
Just sharing... Thanks!
#26
[QUOTE Static weight aint that big od a drag as having heavier wheels.
Just sharing... Thanks![/QUOTE]
So true. We went from stock rims and 35" KMs to ATX slabs and 35" Nitto trail grapples and the milage drop by 2 mpg. Nothing ells changed. We have a 2 door with 4:10.
#27
I'll disagree to an extent with the static weight not impacting MPG...when I put on 33's I was still seeing between 18 and 19 HWY, changed bumpers and the air deflector with the stock plastic bumper disappeared and my mileage dropped to 15-16 HWY. The unsprung weight will definitely slow acceleration a bit, and wider tires will also have a detriment to your fuel economy, but you're driving a slightly mod'd JK so obviously fuel economy wasn't your primary concern.
